- koosjer55
- JDM
- Province/State: The Netherlands
new pics!
Works continues (slowly but surely)..
- Latest score; a NOS rear window wiper set! Only not realy sure the switch - which comes with the set - will work out..we'll see
- P1020632.jpg (144.63 KiB) Viewed 2913 times
- Original shock compared with a CRX shock..needs some work before fitting..there's always hope!
- PC310622.jpg (142.25 KiB) Viewed 2913 times
- Back on its feet again. Engine frame freshly painted with anti-rust and all Superpro bushings installed.
- PC310630.jpg (135.87 KiB) Viewed 2913 times
- Got the suspension back together (for the time being)
- PC310625.jpg (127.31 KiB) Viewed 2913 times
- PC200610.jpg (116.29 KiB) Viewed 2913 times
- On page 1 you can see how this looked before
- PC200604.jpg (136.94 KiB) Viewed 2913 times
- Untitled-2.jpg (124.56 KiB) Viewed 2913 times
- koosjer55
- JDM
3 more pics
- P1030644.jpg (112.45 KiB) Viewed 2847 times
- Finally a good result with the grille. Took me 6 or 7 times, mainly caused by terrible masking tape..in the end finally found a good one, that didn't ripped the paint right off. Also attached the new emblem, looks sweet!
- P1030640.jpg (63.82 KiB) Viewed 2847 times
- Rear chassis parts taken off, cleaning and painting can be started next Friday (incl. Superpro bushings)
- P1030637.jpg (124.63 KiB) Viewed 2847 times
- koosjer55
- JDM
Got lucky with the last '78-'79 emblem CMSNL.com had to offer. A friend of mine has the last '73-'77 emblem they had in stock.
The shocks are indeed from a 2nd gen. CRX ('88-'92). It will be a try-out when all is ready. I'm thinking about putting the front springs on the rear shocks, but I've to gather more info on that.
- koosjer55
- JDM
I actually used very simple Motip paint:
Primer Grey
Wheel Spray Silver
Masking the silver line with Slim Tape Gold and then
Lacquer Black Matt
I'm thinking about clear coating it for more protection, but on the other hand, I don't want it to be glossy.
Primer Grey
Wheel Spray Silver
Lacquer Black Matt
- koosjer55
- JDM
little update
Here's a little update on the project.
- Very happy with the result of a fresh sandblasting (glass/bead blasting) job! Thinking about polishing the outer ring and painting the spokes black, though not quite sure about that..
- P1170653.jpg (147.36 KiB) Viewed 1870 times
- Rear chassis parts all cleaned up and painted with rust protector. Again a couple of poly bushings from Super Pro will enhance the suspension.
- P1170652.jpg (131.36 KiB) Viewed 2605 times
- koosjer55
- JDM
little pic update
Process continues..
- Discoverd some more rust underneath the car...darn
- P2070675_.jpg (91.11 KiB) Viewed 2510 times
- Sprayed it with anti gravel
- P2070670_.jpg (90.79 KiB) Viewed 2510 times
- Painted with Owatrol (stops the rust process)
- P1310665_.jpg (90.86 KiB) Viewed 2510 times
- Fuel tank fix up
- P1310663_.jpg (72.18 KiB) Viewed 2510 times
- P2070673_.jpg (83.13 KiB) Viewed 2510 times
- rear drumbreaks refurbished
- P1300656_.jpg (88.16 KiB) Viewed 2510 times
- koosjer55
- JDM
Back in black!
Just picked my wheels and brackets up from the powdercoater. Very happy with the result and can't wait how they'll look when the tire and centercap or on.
- turbines1.jpg (120.28 KiB) Viewed 2438 times
- turbines2.jpg (122.49 KiB) Viewed 2438 times
