Restoration Islander's First Generation Honda Civic
- HondaCarCare1
- Province/State: Portland Oregon, USA
- islander
- Province/State: Shawnigan Lake, British Columbia
No I wouldn't suggest "panel painting" with a metallic colour. You will run into colour differences for sure. The next step once I move into my new house is to pull all the panels back off, pull the motor, and start the body work on the shell. As far as the HONDA letters and the N being the right way up.... well I have put them on allready, I just double checked and I did put it on upside down :oops:
- The Civic 29.jpg (5.42 KiB) Viewed 13684 times
- Layspeed
- PsychoCiv
- Province/State: Alberta
- Hometown: Edmonton
- Model: 1978 Wagon CVCC
where's my magnifying glass! It looks right side up at that size... :D
'78 Civic Wagon : '91 CR-X Si : '99 Odyssey : '99 CR-V : '77 Civic Wagon : '03 Pilot :
- islander
- islander
Still having problems getting my pics online here. rather frustrating to say the least. haven't got to the nasty rust yet, but the motor is out. All of the suspension in the front end has been stripped and re painted. struts, springs, lower control arms, brake calipers(new re-mand), front cross member, knuckles and hubs, fan and cage, and also drive shafts. A lot of tedious work but well worth the outcome. Cant wait to get my pics on here :roll:
- Eduardo I. Nieves Davila
- Province/State: Carolina PuertoRico
- islander
ya, I've decided to stick with the same engine. I have it fully stripped down just to the head still attached to the block. I noticed one of the intake valves not fully seating so until I do a leak test on the motor I'm not sure how much further I will go. if it's the rings also leaking then all bearings and rings as well as a valve grind will get done I guess. Cant wait to get my pics on to show everyone.
- islander
:D :D Got the picture thing figured woo!! Here we go with some up dates.
- Worn timing chain cover. Junk
- DSC01893.JPG (143.5 KiB) Viewed 13391 times
- My old calipers I tried to fix up, until I found out you can buy re-mand ones for cheep. but this is what they will look like
- DSC01892.JPG (129.57 KiB) Viewed 13391 times
- Hubs all re painted
- DSC01891.JPG (128.95 KiB) Viewed 13391 times
- Drive shafts
- DSC01890.JPG (123.06 KiB) Viewed 13391 times
- lower control arm
- DSC01889.JPG (128.73 KiB) Viewed 13391 times
- front control arms and sway bar
- DSC01888.JPG (127.77 KiB) Viewed 13391 times
- valve cover removed. looks very clean
- DSC01887.JPG (129.36 KiB) Viewed 13391 times
- DSC01886.JPG (134.22 KiB) Viewed 13391 times
- DSC01875.JPG (141.64 KiB) Viewed 13391 times
- islander
got board, took some pics
- whats left of the battery tray
- DSC01894.JPG (129.21 KiB) Viewed 13377 times
- DSC01895.JPG (135.52 KiB) Viewed 13377 times
- DSC01897.JPG (135.78 KiB) Viewed 13371 times
