Steph wrote:Nice work Bob. It looks like there was/is a bit of rust to cut out there. Nothing worse than finding cancer.
Thanks, yea the cancer under the front of the right side rail is pretty nasty. It will be getting cut out and replaced.
Got a few moments to spray the inside steering rack hole area and the outside steering rack area. Taking a break to let it dry. These 40 degree days make the paint take a bit longer to dry. :)
Steering Rack Hole Outside Civic (600 x 443).jpg (55.76 KiB) Viewed 1206 times
Steering Rack Hole Inside Civic (549 x 600).jpg (59.59 KiB) Viewed 1206 times
Finally refinished the rear crossmember and am getting ready to reassemble it to the car. I'm happy with the undercoating and outer coat. I'm not quite sure which way to place the rubber grommet the pinion fits through (pic A or B). :)
Rubber Grommet B.jpg (114.76 KiB) Viewed 1159 times
Rubber Grommet A.jpg (109.89 KiB) Viewed 1159 times
Rear Crossmember before refinishing
Steering rack - rear x-member (600 x 248).jpg (40.93 KiB) Viewed 1159 times
Got the rear x-member and rack re-installed. The LCAs reconnected and the car is now back at the bodyshop to get the metal work done and the engine bay sprayed. :)
Rear Xmember-Mount (600 x 304).jpg (52.31 KiB) Viewed 1131 times
Refinished Lower Firewall (600 x 291).jpg (43.14 KiB) Viewed 1131 times
Jonathan
Province/State: Butler
Model: 1979 Hatchback CVCC
Post by Jonathan »
Looks good! Do you think you'll be ready for the Carlisle show this year?
Jonathan wrote:Looks good! Do you think you'll be ready for the Carlisle show this year?
Very good question - assuming the engine is back in and running! :)
So what was the decision with the engine in the end Bob? Transplant or rebuild?
Steph wrote:So what was the decision with the engine in the end Bob? Transplant or rebuild?
A rebuilt transplant consisting of an a 1600 EF bottom and a ED 1500 top. :)
The only thing I'll be keeping from the old engine are the 3 bent rods as a souvenier. :wink:
Tomorrow might be paint day. :D Here's some pics of metal work & prep. :)
Looking good
Good luck with the weather, ours is +4 deg tomorrow, just 40 degrees fartinheight :shock:
pete
Hometown: Maple Bay
Post by Kurt »
nice work. Those engine bays sure are a bietch to sand out arn't they :(
