Restoration Islander's First Generation Honda Civic
- islander
- Province/State: Shawnigan Lake, British Columbia
- islander
sorta have mixed thoughts about my motor :roll: The previous owner has said that it was re-built... when I took the intake off, I turned the motor over to get the #1 piston to TDC, I noticed that one of the intake valves had "bubbles" forming as I turned the crank. looking at the camshaft once the valve cover was removed is very clean. Do I take the head off for a valve job, and at that point do I do the rings and bottom bearings as well???? what to do, what to do.
It sounds like it is pretty much a judgement call from the way that you describe it. Maybe if you can post some pics that show what you see , someone might have some specific advise.
It is always a tough call when you have to make the decision to pull it apart or not, I usually freshen it up if I take the time to disassemble and inspect a motor.
- islander
You are probably rite, there isn't much left to take the head off and get the valves done as well as do the rings and bearings. Not doing a compression test while the motor was in the car, was a mistake on my part. :roll: did get a chance to finish polishing my valve cover today tho :D
- DSC01902.JPG (128.45 KiB) Viewed 18961 times
- islander
Took some more pics of the prep on some of the misc parts. Radiator fan, front struts, front cross member, backing plates and air cleaner. Not sure what color I should go with on the shocks. Plan on painting the springs red. I am thinking yellow on the shock, kinda like the bilstin color.
- got the top plate striped.
- DSC01909.JPG (143.46 KiB) Viewed 18942 times
- DSC01908.JPG (130.04 KiB) Viewed 18942 times
- air cleaner before pics
- DSC01907.JPG (133.59 KiB) Viewed 18942 times
- front knuckles already have been painted silver. painting the backing plates black. couldn't undo the bolts so I had to mask it up.
- DSC01906.JPG (132.11 KiB) Viewed 18942 times
- front cross member
- DSC01905.JPG (131.96 KiB) Viewed 18942 times
- front struts and springs
- DSC01904.JPG (135.66 KiB) Viewed 18942 times
- fan cage and motor
- DSC01903.JPG (135.15 KiB) Viewed 18942 times
- joshuao
- Mugen
- Province/State: Queensland Australia
