Starting to put the electrical back together.
Can someone show me where the negative ground on the battery cable attaches to on the body?
Also, there is a 2 prong connector that I can not seem to find a mate for? Is this a hookup for a hondamatic or something that I should ignore?
There was a short black ground wire that I didn't label.
Does it belong on the regulator mounting bolt where I placed it?
- Unidentified 2 wire Connector - red (593 x 600).jpg (73.42 KiB) Viewed 1140 times
- Negative Battery Cable Ground - Red (600 x 450).jpg (55.89 KiB) Viewed 1140 times
- Black Ground Wire - Regulator Attached (600 x 450).jpg (63.23 KiB) Viewed 1134 times
- Black Ground Wire - Regulator (600 x 450).jpg (59.33 KiB) Viewed 1134 times
I'm pretty sure you are correct. The question I have is where on the radiator support? I'm attaching a pic that shows what you suggest. However, it is blocked by the ac receiver.Jonathan wrote:I think there is a ground wire mounted to the radiator support. I will check my car tonight.
Also, the unidentified connector comes right off the main loom not far from the firewall. It is solid black and solid green to my eye.
- DSCN6107 (600 x 450).jpg (71.21 KiB) Viewed 1124 times
- Unidentified 2 wire Connector -1 (600 x 558).jpg (63.31 KiB) Viewed 1124 times
- Negative Battery Cable Ground 2 - Red (600 x 450).jpg (66.83 KiB) Viewed 1124 times
Black and green -screenwash bag , fitted onto the battery retaining strap on uk models.
Neg wire attached to trans/gearbox, then trapped behind top mounting bolt of radiator [this being a brass/copper plate, rather than a spade connection.
Plus earthstrap from camshaft cover to hinge panel on ours.
All based on uk experience, may of course differ, elsewhere.
Hope it's of some use
Pete, thanks for the post. I was just going through my service manual and made the "pee bag connection".Thor wrote:Black and green -screenwash bag , fitted onto the battery retaining strap on uk models.
I guess I should mount the radiator and AC fan and things should start to fall into place.
If possible, if anyone can post a pic of the neg wire where it attaches to the radiator would be helpful
