Restoration Islander's First Generation Honda Civic
islander
Province/State: Shawnigan Lake, British Columbia
just an up date.
Post by islander »
I got some more parts painted finally. I also noticed my neighbor has a 78' civic, covered in pine needles. I talked to his mom today because he is away this weekend. Will try and score this fine parts car. not much to look at, but it does have a mint front gravel pan I could use and a standard trans. The gear shift says 5 speed, but I wasn't able to get a real good look to see if that really was what it is. I'm sure there will be a few more useful things left on the car tho. will definitely keep you all posted. I will put a call into him on Tuesday. Oh ya I almost forgot, took the head off of the motor today will be taking it to the machine shop tomorrow. Kinda feel like I'm jumping into the deep end of a pool, trying to learn to swim with this whole motor part of the build.
front cross member and lower engine mount
Radiator fan and motor
front shocks awaiting the springs
Its all looking good! will be a good looking engine room for sure!
islander
Post by islander »
It feels like I have soooo much to do before I will get to see all of the big picture put back together. Certainly teaching me patience.
islander
More paint work
Post by islander »
Was able to get a few more parts painted today :D Also took the head into the machine shop this week. There wasn't much wrong with it, other then a few leaking intake valves and suggested valve guide replacements. Ended up ordering a re-mand head. Haven't been able to get it yet. Should be ready to go on Monday :D $490.0 latter. :shock:
islander
Post by islander »
Got the head back today :D I noticed that the rocker arm/valve clearance adjustment wasn't set. Is this supposed to be done with the head on the block? Also is a puller needed to take the camshaft pulley off? I would like to remove it for paint.
Just had to put the cover on to see what it is stating to look like.
JAF Mugen Power
Province/State: Koga
Post by JAF Mugen Power »
Looks good.
islander
Post by islander »
Started on the trans today! Very tedious. Stopped sanding at 1000 grit wet and did a sample polish and the end. Will be a lot of work to make it look shiny. Also painted the head and oil pan.
Stopped at 1000 grit wet.
before
before
islander
Post by islander »
Finally got the trans done... The pics didn't really look as god as it does.
steve.ewing@ottawa.ca
Hometown: Kemptville
Model: 1976 Hatchback
Post by steve.ewing@ottawa.ca »
Nice work. I've been doing a lot of the same kind of work lately so it's fresh in my mind how much work goes into it. I stopped way short of where you did with my trans but I did get it nice and clean. Looking forward to the finished product.
So how did you finish it up? I saw where you said you were using really fine paper, wet I imagine, so what came after that?
I love polishing metal, and plastics too! :)
