Jonathan wrote:Bob, do you still have points or an electronic ignition? When I still had points, I had two of those symptoms (timing off and hard re-starting). When I converted over to the Pertronix kit, both went away.
I do have a Pertronix kit in wait. I was hoping to make use of
the new points before I converted.
I'm not so sure the timing is set right. :)
Pop that Pertronix in right now!!!
You'll wonder why you ever persevered once you've used it. :wink:
Jonathan
Province/State: Butler
Model: 1979 Hatchback CVCC
Post by Jonathan »
Thor wrote:Pop that Pertronix in right now!!!
Seconded. I'll never go back to points again.
OK, will do and for good measure I just ordered a flame thrower coil to go with it. :)
Went out for a drive earlier today.
On the highway, the car began losing some power
and felt like it wanted to stall. I made it off the hwy
and on the way back home it stalled out several times.
At one point the fuel pump was going a little bonkers.
I had plenty of gas sitting in the fuel filter in the engine bay.
I looked at the fuel filter under the rear seat. It too looked
full of fuel and pretty clean. Any thoughts on how to proceed? :)
Jonathan
Post by Jonathan »
Hrm, possibly a weak pump? It may flow enough under part load, but not under a higher load after a few minutes? Did it seem to run relatively smoothly as if there was still consistent spark? About how long did it take on the highway before the problem started?
make sure there is fuel in the tank and then do a flow test at the carburetor line.
Jrods77
Owner
Owner
Province/State: Nashville, TN
Post by Jrods77 »
Great Inspiration!
I had a bit of buyers remorse when I first bought my civic. Now its like I'm falling in love.
Here's some quick pics of the stripes. :)
DSCN1474 - B.jpg (86.3 KiB) Viewed 1018 times
islander
Province/State: Shawnigan Lake, British Columbia
Post by islander »
WOW Bob they look great!
Every old car deserves a second chance!
