- koosjer55
- JDM
- Province/State: The Netherlands
- koosjer55
- JDM
Here's a little preview on how to door panels look like. Maybe I've put the left doorpocket on the right side btw, but this is the only way they fit with my new seats in. Looks fine by me. Also the sound of the door shutting is really solid thanks to the Dynamat.
Next week I'll post some better pics (have a new camera that will capture the true colours more easily 8)).
- IMG_0006.jpg (145.85 KiB) Viewed 1631 times
- koosjer55
- JDM
Thanks man!
Just duplicated one of the stickers underneath the hood (on European and Australian Civics only, if I'm correct). Instead of the orange/white I went for black on transparent (my printer isn't very steady with colours). Did my best on getting it as original as possible, but changed the 4MT into 5MT
- The new customized one
- IMG_0072.jpg (148.16 KiB) Viewed 1136 times
- The old torn one
- P3210226.jpg (138.41 KiB) Viewed 1685 times
- koosjer55
- JDM
I made a new one and printed it out on label-sticker-paper (large labels), after that I sealed it with a transparent printable sticker sheet and wiped the printable top layer off with a moist cloth, so the transparent sticker gets completely clear. It's a bit of a Mcgiver way and can be done on several easier ways, but it works :D
I went for white label-sticker-paper cause transparent wouldn't really turn out very nice. Also made a little decal for on top of the regulator cover where normally the battery caution decal is. I have that decal somewhere else. Don't know if it will look right, will see tomorrow.
- IMG_0073.jpg (141.82 KiB) Viewed 1627 times
- koosjer55
- JDM
Sure, send me over what you want.
Btw, engine is in! :D Was pretty tough to do, cause of the 5speed, the room to manoeuvre was very very little, but we made it and it looks sweet 8)
- Ride height is nice this way, so far so good with the Kings!
- DPP07D90C05172614.jpg (147.71 KiB) Viewed 1039 times
- Sticker is looking pretty stock
- DPP07D90C05172439.jpg (148.71 KiB) Viewed 1039 times
- DPP07D90C05171D24.jpg (143.7 KiB) Viewed 1018 times
- DPP07D90C05172B14.jpg (140.38 KiB) Viewed 1039 times
- Mom is keeping a close eye on it from a safe distance
- DPP07D90C05173238.jpg (141.52 KiB) Viewed 1039 times
- DPP07D90C05171A54.jpg (148.34 KiB) Viewed 1039 times
- koosjer55
- JDM
Little update on the project...including a pic of the nasty dent, I talked about earlier :( Any way, made a start with the missing exhaust piece that connects to the RS manifold. Everything goes well, including my custom made gasket, so hopefully I can finish the piece this Wednesday. TBC and everybody a happy new year in advance! :D
- Bought a replacement dash cause my dash is a bit damaged. This one will do!
- IMG_0154.jpg (138.19 KiB) Viewed 1107 times
- IMG_0159.jpg (149.63 KiB) Viewed 1107 times
- The metal piece is 5mm thick, must be enough, I think.
- IMG_0158.jpg (148.99 KiB) Viewed 1107 times
- This is what you get when you use a too tiny jack..
- IMG_0156.jpg (149.08 KiB) Viewed 1107 times
- koosjer55
- JDM
- koosjer55
- JDM
I used tons of steel wire wheels. After that I sprayed the engine with Motip engine paint
