Restoration Islander's First Generation Honda Civic
- islander
- Province/State: Shawnigan Lake, British Columbia
well.....Been busy, can't say I wouldn't be happy if I never had to do another RUST patch in my life. Needless to say moving forward with the reconstruction of my car. Also had the time to get a few more bits and pieces painted at work this past week. I don't have any pics of the gas tank stripped to bare metal, but once i did it was in fabulous shape also finished off the front and rear suspension parts too. I took the brake lines to a hydraulic shop to be all re done and in place of the rubber flex hoses, I am going with stainless braided 8) . well here are the pics for now.
- front and rear suspension
- DSC02449.JPG (132.54 KiB) Viewed 1127 times
- left rear
- DSC02439.JPG (132.69 KiB) Viewed 1127 times
- break booster
- DSC02448.JPG (117.9 KiB) Viewed 1127 times
- DSC02447.JPG (131.38 KiB) Viewed 1127 times
- left side rocker
- DSC02446.JPG (136.61 KiB) Viewed 1127 times
- left side rear
- DSC02445.JPG (141.24 KiB) Viewed 1127 times
- right side rear
- DSC02442.JPG (130.99 KiB) Viewed 1127 times
Every old car deserves a second chance!
- islander
- islander
Making the big push to get my car down to the paint shop for prep and paint!!! The past little while I've finished up the welding :D and moved on to the filler part of the resto. Every thing has been given a lick of filler just to make sure its going to be straight. Here are some pics, pretty boring but non the less pics of progress.
- rear seat. both sides ended up needing to be rebuilt.
- DSC02456.JPG (137.99 KiB) Viewed 1213 times
- left side
- DSC02455.JPG (140.75 KiB) Viewed 1213 times
- gravel pan looking straight
- DSC02454.JPG (135.75 KiB) Viewed 1213 times
- right side
- DSC02453.JPG (140.07 KiB) Viewed 1213 times
- action shot....sanding away
- DSC02452.JPG (126 KiB) Viewed 1213 times
I need to know your paint colour code, and which ones you had before, as some of yours are different to ours. Once I know that I'll make up a sheet of them. I just switched my printer over to a continuous ink system, which is one of the many things I had bought and not fitted. I printed a test sheet on semi-gloss paper and the quality is astounding. I also printed registration marks for the first time! I'd been trying to do it in FlexiSIGN Pro, but the print quality was no good. Now I have to work out how to contour cut them on the vinyl cutter and I can start making them. I've already made a set before, but I had to cut them out with an Olfa knife. This isn't the way to do it IMO because it's too easy to make a mistake and end up with a crooked cut, or uneven edge.islander wrote:Thanks Steph. Just didn't want to get to carried away with what seems as minor progress. Cant wait to have those new engine bay decals
