EK1 rebuild Swap 1977 CVCC Honda Civic
Eduardo I. Nieves Davila
Province/State: Carolina PuertoRico
Post by Eduardo I. Nieves Davila »
Well is about time i take ona project and post it here :D , Ive been talking about it but no pictures so here they are :) .
Well i have a red 77 cvcc which will be having an ek1 i took out of a parts wagon that had it swaped in there. The bad news is that it was an automatic, so ill have to machine the flywheel just a little to make the civic trany bolt to the ek1 block( as comented on roadsailing.com, thanks Kurt). I managed to get all the parts i needed to make the rebuild posible, but im still mising the tube that goes behid the block, wich will be custom made because i can find it anywhere and the one that the block had was all rusted out. The motor will be restored to look and work good.
I also have some pics of the valve cover mods i will be doing to the ek1( inspired by frankaj :D )
Picture 210.jpg (34.11 KiB) Viewed 4155 times
when the engine was separated from the cross member and placed on a stand to be washed.
this is the front view of the mess.
This is the dirty engine when i got it.
Copy of 2008_0821ytduyu0129.JPG (21.54 KiB) Viewed 4151 times
Copy of 2008_0821ytduyu0130.JPG (23.01 KiB) Viewed 4151 times
Copy of 2008_0821ytduyu0113.JPG (14.8 KiB) Viewed 4151 times
Copy of 2008_0821ytduyu0112.JPG (16.08 KiB) Viewed 4151 times
Copy of 2008_0821ytduyu0121.JPG (24.82 KiB) Viewed 4151 times
Copy of Picture 216.jpg (23.08 KiB) Viewed 4151 times
Update :lol:
Well here you can see the technique i use for taping the block, i put tape on, hit the corners with a small hammer and then take the exes tape of. The block is already primered, and painted black( painted pictures asap)
Also pics of cylinder head being dismanteled( uptdate as soon as i get to fix it :) )
Oh and sorry for the bad organization, its the first time i start a documented project, but not te last, enjoy :D
Copy of 2008_0821ytduyu0087.JPG (29.56 KiB) Viewed 4144 times
Copy of 2008_0821ytduyu0085.JPG (36.09 KiB) Viewed 4144 times
Copy of 2008_0821ytduyu0128.JPG (25.98 KiB) Viewed 4144 times
Copy of 2008_0821ytduyu0127.JPG (24.35 KiB) Viewed 4144 times
Copy of 2008_0821ytduyu0126.JPG (16.61 KiB) Viewed 4144 times
Copy of 2008_0821ytduyu0125.JPG (21.04 KiB) Viewed 4144 times
Why not the flourescent :lol: ? Its the last thing in the corner you know
Update :D I finally go to paint the timing covers and other part, will update of the parts painted asap, here are some pictures of what ive been up to.
test fitting the 1200 emblem after being completely trimed
heather being washed
closeup
closeup
closeup
closeup
panted and trimed
panted and trimed
ready to be trimed and painted
clean ready for paint
cleaned the pan withprekleno
sanded the oilpan with 220 sandpaper
yust washed the oilpan and the degreaser took all the paint off!
The engine bay is going to be gloss red and the block is black, also the oilpan. I like the ideas you guys posted but still have to think a bit about it, im leaning towards the dark gray.
well, me again, finally :lol: .I painted the block and replaced the coolant plugs. I also got the block bored 40 over because the cylinjders where too badly rusted( i tried remving it with honing but the depresions where too deep).It costed me 100 bucks to bore and hone the block and mount the pistons on the rods.Im currently in the process of plastic gauging the crank journals.Enough words, here are the pics :D[code][/code]
civicdfdf 055.jpg (30.64 KiB) Viewed 3831 times
civicdfdf 142.jpg (34.38 KiB) Viewed 3828 times
civicdfdf 141.jpg (22.48 KiB) Viewed 3828 times
civicdfdf 140.jpg (24.39 KiB) Viewed 3828 times
civicdfdf 139.jpg (19.26 KiB) Viewed 3828 times
civicdfdf 138.jpg (16.85 KiB) Viewed 3828 times
civicdfdf 134.jpg (25.02 KiB) Viewed 3828 times
civicdfdf 057.jpg (42.44 KiB) Viewed 3828 times
civicdfdf 056.jpg (31.22 KiB) Viewed 3828 times
Sorry, i uploaded a photo twice :x .Well here are pictures of the finished valve cover.I basically glued the emblem with the epoxy used to join car parts.The valve cover usually gets only 180 degrees, and it should be able to hold up, if it doesnt ill let you guys know.Coments and sugestions for future projects are readily welcome.I originally wanted smaller pistons(20 overbore) but i couldnt find anything smaller than 40.
The valve cover looks browner in person. I sure have to learn to be more organized when posting :lol:
civicdfdf 155.jpg (30.15 KiB) Viewed 3812 times
civicdfdf 154.jpg (34.16 KiB) Viewed 3812 times
civicdfdf 153.jpg (25.66 KiB) Viewed 3812 times
civicdfdf 152.jpg (25.4 KiB) Viewed 3812 times
civicdfdf 151.jpg (26.68 KiB) Viewed 3812 times
civicdfdf 149.jpg (26.82 KiB) Viewed 3812 times
civicdfdf 147.jpg (49.61 KiB) Viewed 3812 times
civicdfdf 146.jpg (42.54 KiB) Viewed 3812 times
civicdfdf 145.jpg (41.7 KiB) Viewed 3812 times
Last edited by Eduardo I. Nieves Davila on January 29th, 2010, 9:05 am, edited 1 time in total.
Bad news, one of the pistons was badly installed and it was broken, i my dad didnt really look at them when he picked them up( though i thank him for his help alot).He will go tomorow to see if the man will change the piston again, ill have to buy another 40 over pisto, the store i bought it from said they had a couple or so left so its not something to worry about.Good think it only cost 10 bucks each, dont know if they will sell me only one or two.
Bought a set of four pistons just to change one, my dad ended up changing it and was a better job all around than the machineshop had done. :D
