Project Martin's 1975 Honda Civic CVCC
thesmogman
Province/State: Tri Valley-Pleasanton/San Ramon
Post by thesmogman »
HI Everyone,
I just realized that I don't have my build on here so here it goes...
The day I got her
Then started on getting her running
After some brake work I got talked into doing the paint
Feather-fill primer
And a little paint
And then reassembled
And this is the end result
Hope you enjoy the short version..
Martin
thesmogman
Re: Martin's 1975 Civic CVCC
Hi All,
Well after a speed bump incident, I had a little problem with power to the fuel pump and replacing most of the circuit I found three fuses burned.
I still do not know what happened????? But with replacing things she (Sally) is running great. No tap, tap, tap from the new fuel pump. Purring like a kitten.
So I drove her home last night all shined up and ready.......for RAIN! Just my luck I guess.
No, she is not done. I have done small things like painted the center caps and installed a new headliner.
I do have ton's of pic's of the restoration. Someday I will download them for a serious build series...
Thank's for the kind words of my work, I love this place!!!
Martin
If you have to fix it, fix it better than it was!
thesmogman
The primer was suggested to me by the painter, just normal automotive primer in a can from the paint shop. Then there was the "featherfill" primer to get the final sanding smooth. It is a very thick primer that you use with using a guidecoat of black so you can see all the high and low spots while sanding.
Then used a sealer coat just to be sure that the paint stayed stuck. I went with a dark sealer as I wanted to have a darker brown.
The paint was not matched to the original(But I wanted to) It is Pimco base for 79 thru 83 ford's.. three coats. Then I went with the good stuff Dupont chrome clear. It was expensive but I wanted it to last. Another three coats of clear.
Then wet sanded with 1500grit the entire car and buffed til I was happy. The only part I did not do was spray the paint and do the buffing.
I probably have well over 100hrs just in sanding first getting rid of the old paint/rust, then body filler, then primer, then featherfill, then finally the wet sanding of the clear. It is the first car I have done this to a big thanks goes out to my painter Chris Coatney of Coatney Customs for walking me thru the process.
