the hub and disc are the same as the civic i just followed the forum's tutorials
just a spacer on the back to center the disc to caliper and hold the back dust shield.
The front is really bad the wheel sticks out of the fender and can't go more inside
i will be using the crx bearing to be able to press the crx/civic front hub with a spacer behind the bearing and a custom top with 4 screws because the bearing is 6mm longer and i need the hub to go outwards.
Last edited by CrAzY_DrIveR on March 16th, 2017, 9:42 pm, edited 2 times in total.
