Michael Bradford’s 1978 Honda Civic 1200
I’ve had the car for about 5 years now and spent a good part of 4 years rebuilding it to the standard that you now see before you. I bought it as a $400 ex shopping car and started pulling it apart almost straight away.
The first rebuild that I did took about 12 months and I painted it myself in red, had the engine conversion done, got it about 90% complete then decided that I wasn’t happy with the result and started pulling it apart again. This rebuild has taken me about another 2 – 3 years.
I got it professionally re-sprayed and spent a lot of time trying to make it as neat and clean as possible. I finally got it engineered and took it to the rego authorities. The car passed with flying colors even with the amount of mods that have been done. They were impressed that I had spent so much time trying to ‘get it right’ so it would pass. The result was worth it.
From Australia
Vehicle Specifications
Wheels:15 x 6.5
Tires:195/50
Exhaust:2.5 inch exhaust system with 3 inch dump.
Performance Modifications
Engine : 1984 ER Turbo Standard T1 ER Turbo conversion. Lightened flywheel and new clutch. Air pod filter. Battery moved to the boot. 4×100 stud conversion. This was done properly with front CRX set-up and rear EN1 wagon drums. 15 x 6.5 inch wheels with 195/50 tyres all round. Front and rear suspension has been powder
coated or repainted. 2 inch lower springs all round with Tokico struts. Adjustable strut tops by Noltec. and lengthened lower control arms gives A LOT of neg camber. ( about 4 deg, a bit more that required I usually run around 2.5). Rear has about 1.5 deg neg. Noltec bushings all round. Mods to come are some stronger sway bars
and adjustable caster bars on the front.
Interior Modifications
The interior has re-trimmed Recaros with the Civic Type R badge stitched to the center. 4-point race harnesses, Accord speedo and tacho and 6 VDO engine monitoring gauges along the dash board. New carpet, Momo steering wheel and gear knob. PLUS a multitude of small changes and mods to clean things up.
Exterior Modifications
All tags removed from engine bay. Custom front Mugen spoiler and shortened front and rear bumpers.( All custom done by myself)Front and rear guards have been rolled and pushed out. All badges removed except a specially made CIVIC TYPE R badge that is on the boot. The boot latch has been removed and a special set-up with solenoid connected to allow for auto boot realize. Only one door lock, drivers side. RS bonnet vents for cooler engine bay.
Sound System
Pioneer stereo.
Save
Save
Save
Save
You May Also Like
Leave a Reply
