Project MIELKO First Generation Civic SB1 from Holland
mielko
Province/State: Europe,holland
Post by mielko »
Took off the tires,
And started cleaning them,used a hand drill and some cutters and brushes.
And took them to powdercout,they are gona be brownish kopper/gold.
I hope they will look fine!
I made a start on the EN4/EB1 hybride.
I had a stuck engine and took it apart,1 piston was locked,and it took some effort with solvents and oils to take it out.
But came eventualy.
The onely thing i could not get of for now were the piston ring on that piston.I need to find a way to get them of without breaking the piston.
Meanwile searching for new bearings and ring eg.
I'v washed the small block in my dishwasher ,and its clean now.
some dirty parts
I cleaned the EB1 head with a koperbrush on a hand drill.
If you compare EB1 and EN4 head,you can see a big differance in volume of the combustion chambers?
You can soak or spray gasket stripper on the piston to loosen/remove any carbon buildup.
If the edges of the ring lands are pushed over the rings a utility knife on the edge of the piston will help relieve the rings.
If needed, a Vibratory engraver on the ends of the rings will usually move the rings past the sticking point and not destroy the pistons. Good luck!
mielko
Post by mielko »
Pickt up my wheels today,
I like um!
Inside they look brownish,outside the look more gold,and a sparkle apears in direct sunlight.
What you think?
Vulcan
Province/State: Seattle
Post by Vulcan »
Looking very promising!
If the book says it can't be done, do it anyway.
Blackbullet
Province/State: ..
Post by Blackbullet »
Not sure on the wheel colour, need to see them outside so they sparkle :)
Ive been comparing me heads too. The EB1 chambers are much smaller. I am going to get a syringe and measure them when i get time
turbogeek
Post by turbogeek »
I really like the fabrication work!
coming along nicely!
mielko
Post by mielko »
We had a rally last weekend ,and made first pics with the new wheels!
mielko
Post by mielko »
I bought a nardi wheel for 10Euro with the wrong hub.
No problem,then make my own .
how its gona be
weld and spray
finished
Easy :D
Nice work, you can't even tell! :)
sobe_death
Province/State: Denver, CO USA
Post by sobe_death »
Nice! 10€? Where did you find that deal? All the Nardi wood wheels in the US are $100+
