Project MIELKO First Generation Civic SB1 from Holland
- mielko
MIELKO First Generation Civic SB1 Project from holland
No machining needed!
- mielko
Cleaned the original EB1 engine before taking it to the machine shop .
First wet blasted the engine,then rinsed it with a hose.Than washed in dishwasher for 2 hours
A lot cleaner
Brought the engine to Logmans for boring and honing .Should be ready in a weak or 3 .https://www.logmanstechniek.nl/motorenrevisie
A lot cleaner
- mielko
the (dis)advantage ,of having more then 1 vehikel is that you have more stuff lying around.
So i was loking at 1 of my bikes and got a idea...........
To the attic .........
Where is that cilinder head......
There it is....
Now where are thos other parts...
A,here they are ......
what the h.....
it is made for each other
CV carburateurs of a honda cb750 .
Where are my left over bits stainless....
1 hour of hand grinding and drilling
to be continued .
There it is....
what the h.....
to be continued .
- mielko
Got my engine back from machine shop,painfull on the budget....
luckely i can do the rest myselve
Also found time to go further with my adj camgear.
To do:
countersunk
make slots for adjusting
cut gear in 2 pieces
Nu verzinkboren zodat deze verzonken bouten netjes weg vallen
Dan nog sleuf gaten maken,en de nokkenas in 2en zagen.
To do:
countersunk
- Blackbullet
- Province/State: ..
The Kawasaki pistons fit ok but the deck height is much less so you will have lower compression. I cannot see the benefit of these pistons. Here the pistons are linked together by the piston pin. Kawasaki piston on the right
- mielko
Yes Iknow.
The deck Will be skimmed to fit The piston.
Adjustable camgear Will sort The timing difference deu to lowering the deck hight.
I Will also use 1300 crank. And The longer 1200 rods
- Blackbullet
- mielko
Not my idea.
Great thanks to Steph!
- mielko
Re: MIELKO First Generation Civic SB1 Project from holland
To show that its not always neccesary to own a big machine park ,here proof
A cheapo wallmart figure saw to open the slots
Than less DIY
Put my conecting rods in my lathe
An old one as first to try it first
The real deal
https://youtu.be/dfJFDRMCVRE
Now i can equal them,as i have 3 times 380gram and 1 382gram ,so 2 gram off difference .not much!!
Not that i will ever notice this total difference
But just because i can
Than less DIY
The real deal
- mielko
Eindelijk deze is ook klaar .
https://youtu.be/mtP3RzSXZaA
