about 3 years ago I purchased my 1977 honda civic 1200. Completely stock.
Dad and I begun to restore it to it's former glory, and make a lot of modifications along the way.
As I am not the greatest with mechanics Dad did a lot of the work and I helped as much as I could along the way. Ended up working out that Dad did a lot of the work and I supplied nearly all the cash, so it all evened out :lol: :lol:
These are pictures of the various stages of the build all over the site, but I thought I would upload a few of them into one thread so others can see what we've been up to. I'm sorry there aren't more of the different stages, I really regret not taking more photos.
I hope you enjoy :)
Regards
Jacob
Mine and Dad's project 1977 Honda Civic 1200
- Jacob Hanley
- Province/State: Country Victoria
- Began wiring up a sub and amp.
- IMG184.JPG (49.05 KiB) Viewed 4655 times
- Speakers in the rear inserts
- IMG183.JPG (30.77 KiB) Viewed 4655 times
- Tacho.
- IMG185.JPG (34.09 KiB) Viewed 4655 times
- Next came the weber.
- RIMG0023.JPG (92.32 KiB) Viewed 4655 times
- Dad then fabricated a set of extractors, 4-2-1. This is before plating them.
- Extractors before plating.jpg (94.63 KiB) Viewed 4655 times
- Honda red!
- honda.jpg (28.2 KiB) Viewed 4655 times
- Painted the engine bay, and dropped in the just rebuilt engine and 5speed gearbox.
- new engine bay.jpg (90.88 KiB) Viewed 4655 times
- I wish I had taken more photos, this is straight after we converted to 4x100.
- 22032010.jpg (28.58 KiB) Viewed 4655 times
- Engine then pulled out and sent away to be rebuilt. Was a relief to finally get it all back so we could start assembling it.
- 14052010.jpg (35.06 KiB) Viewed 4655 times
- What we started with. Washing it down after buying it.
- IMG_1218.JPG (79.19 KiB) Viewed 4655 times
- Jacob Hanley
Some more . .
- 1 3/4" custom exhaust fabricated by dad, with a 2 in muffler that I think was stock for an Holden SS. Sounds fantastic!
- IMG152.JPG (30.91 KiB) Viewed 4651 times
- IMG151.JPG (50.03 KiB) Viewed 4651 times
- IMG148.JPG (56.76 KiB) Viewed 4651 times
- Beginning the paint job.
- IMG118.JPG (44.14 KiB) Viewed 4651 times
- Jacob Hanley
and more. . .
- Second road trip since getting it on the road!
- IMG572.JPG (37.26 KiB) Viewed 4639 times
- IMG553.JPG (31.39 KiB) Viewed 4639 times
- My previous run-about in the background.
- IMG545.JPG (41.56 KiB) Viewed 4639 times
- I think my girlfriend was suitably impressed with the '77!
- IMG906.JPG (39.72 KiB) Viewed 4639 times
- IMG905.JPG (32.88 KiB) Viewed 4639 times
- THe finished product!
- IMG546.JPG (48.33 KiB) Viewed 4639 times
- The frustrating problem of finding a windscreen rubber in Aus. Ended up making do with a rubber off a toyota hilux.
- IMG389.JPG (46.15 KiB) Viewed 4639 times
- I think the product we used to fill the roof channels was called stickaflex, we then covered that with stripping bought from repco.
- IMG392.JPG (29.07 KiB) Viewed 4639 times
- Jacob Hanley
A list of everything done to my car.
-Engine/Exhaust
1 3/4in Exhaust.
2 1/2in Chrome Tip
2in Straight Through Muffler
Aftermarket heater tap in engine bay.
Custom extractors 4-2-1, courtesy of dad
Eb3 head.
Eb3 pistons.
Engine re-bore and rebuild. Eb2.
Heat shield for extractors.
Larger diameter radiator fan.
-Drivetrain/brakes/suspension
2nd Gen 5 speed.
Rebuilt CVs
2nd Gen brake conversion . 4x100 stud pattern
New Brake Master Cylinder, and Booster.
New Strut caps.
-Interior
600W amp
cd player with mp3 auxillary connection
Front Tweeters.
Polk Audio 6in Speakers.
Sub woofer
VDO Tacho.
-Exterior
New 2pac Paint, original white.
14in rims
Honda "H" Wheel Center Caps
-Performance/electrical
2nd gen electronic distributor
70amp 2003 toyota hilux alternator.
Eb3 intake manifold. Modified.
Electronic Fuel Pump
Mild-Hot Street camshaft
Modified stock airbox to suit 32/36.
32/36 weber
At the moment there are few things being fitted to the car.
*Adjustable timing gear, absolutely amazing results!
*Aftermarket 3 core radiator.
*Aftermarket redline air intake.
*200W RMS 12" Kenwood Subwoofer.
I couldn't believe how good the extractors turned out!
The coolest thing was he only had extremely basic tools to fabricate them with.
Dad is damn good at making high quality products using just a welder, an oxy and a grinder.
So the new 3 core radiator and the adjustable timing gear are fitted, timing issues are now fixed!
And wow does it go hard now, it is very quick!
-Engine/Exhaust
1 3/4in Exhaust.
2 1/2in Chrome Tip
Eb3 head.
Eb3 pistons.
2nd Gen 5 speed.
Rebuilt CVs
New Strut caps.
-Interior
600W amp
Front Tweeters.
Sub woofer
VDO Tacho.
-Exterior
14in rims
32/36 weber
