1200 Civic Service Information
This section you will find 1200 specifications, transmission, and paint charts. If you are new to these cars, then you must check out what are the differences between a CVCC to a Spex Elf kit car. Find out what options came in stock with each different model, and you will see how easily they are interchangeable. Not all models of these cars were available to north America for example the Special X only saw the Canadian markets and the R.S. is the JDM of the Civics’.
If you are looking for engine swaps or a turbo setup take a quick look at the City Turbo before you head off to the Engine Swap section of this site.
Posted: February 3rd, 2017, 8:40 am
by Randy
1200 Civic Service Information (Non-CVCC)
Lubricants
Engine5.3pts or 3 LitresCastrol GTX
Gearbox
Manual Transmission4.5 pts or 2.5 LitresCastrol GTX
Hondamatic4.5 pts or 2.5 LitresCastrol TQ Dextron
Wheel bearingsCastrol LM Grease
Engine1169cc1238cc
Capacity71.4cu in.75.5 cu in.
Bore70mm72mm
Stroke76mm76mm
Compression Ratio8.1:1 (8.3:1 USA)8.1:1
RotationAnticlockwiseViewed from the pulley end
Valve Clearances(Cold)
USA type (Inlet & Exhaust)0.13 – 0.17(0.005-0.007)
Other types (Inlet & Exhaust)0.10-0.14(0.004-0.006)
Valve numbering sequence (from timing belt end)
Inlet Valves1,3,5,7
Exhaust Valves2,4,6,8
Cooling System
System capacity4.2lirres (4.4 quarts us)
Fan operating temp88.5deg-91.5deg cel(176deg – 183deg f)
Fuel
Fuel pump pressure2.5lb f in20.18kg cm2
Fuel tank capacity37.8L (10US gallons)
Spark Plugs1169cc1237cc
NGKBP-5ES, BP-6ESBP-6ES
DensoW-20EP, W-20EP, W-22EPW-20EP
Gap0.7-0.8mm (0.028-0.031″)0.7-0.8mm (0.028-0.031″)
Firing Order1,3,4,2No 1 cylinder being at the timing belt end
Gear box RatioManual 4 speedHondamatic1169cc1238cc
1st3.00:11.521:11.636:1
2nd1.789:11.034:11.034:1
3rd1.182:1
4th0.846:1
Reverse2.916:12.045:12.045:1
Tires600s 12-4PR24psi all around
Front wheel AlignmentCastor 1Deg 45′
Camber 30′ positive
Toe Out 1mm (0.04″)
Rear AlingmentCamber30′ positive
Toe Zero
Brakes
Disc BrakesThicknessService limit
9.6mm (.03780)9.0mm (0354)
Drum Brakes Internal Dia180mm (7.086″)181mm (7.126″)
Hand Brake Adjustment1-5 notches on lever
Brake FluidSAE J1703 or DOT 3,4
Electrical12V – ground
Battery20hr @ 32 or 45 amp hour
Alternator12V14V @ 1200rpm no load
14V@ 5000rpm 35ampsif air 820rpm
Voltage Regulator13.5-14.5 volts
Weights (kerb)1973-1974 Manual1621lb (775kg)
1973-1974 Hondamatic1638lb (743kg)
1975-1976 Manual1716lb (780kg)
1975-1976 Hondamatic1738lb (790kg)
1977-1978 Manual1687lb (765kg)
1977-1978 Hondamatic1709lb (775kg)
1979 Manual1696lb (769kg)
1979 Hondamatic1711lb (776kg)
1200 Service Data
Leave a Reply
