BLOWN HEAD GASKET???????
First Generation Civic Discussion Board: First Generation Civic Discussion Board: Loads of new parts avalible for 1st and 2nd Gen Civic's!!!!!!!: BLOWN HEAD GASKET???????
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Michael Roberts (209.86.22.133) on Friday, January 19, 2001 - 03:10 pm:
I HAVE A 93 CIVIC WHICH I THINK HAS A BLOWN HEAD GASKET. IT RUNS FINE WHEN I FIRST START IT UP. THERE IS A BIT OF WHITE SMOKE IN THE EXHAUST. AFTER ABOUT 10 MINS., IT WILL START TO IDLE ROUGH
AND THE WHITE SMOKE WILL BILLOW OUT. IT SEEMS TO USE A BIT OF COOLANT ALSO. ANY COMMENTS?
THANKS,
MIKE
Top of pagePrevious messageNext messageBottom of pageLink to this message   By errol (152.163.204.206) on Tuesday, January 23, 2001 - 05:42 am:
Don't drive it!! The coolant will break down the lubricating properties of the oil and you will glaze and score the walls and eat at your bearings. And don't wait too long before you get it fixed, the rings could/will rust in the cylinders. Find out why it blew. Did it overheat? if so check the thermosenors that kick the fan on. Ohter wise you could run into the same problem after the head fix.
