I have an EB3 block
and the big valve cylinder head.
I thought that the EB3 was from the 80-1 Civic 1300 so that's the car I think I ordered timing belt, water pump for - yet neither fit.
Timing belt is easily 10 teeth too long
Water pump sticks out way too much to even have a remote chance of bolting on.
Another thing, attached to my cylinder head is a distributor with no vacuum advance of any kind (this is an ex-SCCA race car), the distributor rebuild parts I was sent also do not fit - any ideas what the correct car to order them for is?
Thanks.
-e
EB3 is 78-79 1200, uses the same timing belt as an 80-83 EN1 though. EN1 water pump also fits, but not if using an EB timing cover. Sounds like they gave you parts for completely the wrong engine.
A 80-1 Civic is a EJ block. I believe i am correct in that th EB3 was a 78-79 1200 engine.I have no idea about the distributor unless it was converted to electronic ignition. Hope this helps.
Goodluck and Godspeed,
A.W>
Adrian,
Correct me if I am wrong...
The big valve cylinder head is also from the EB3 engine right? Or not? Once I know exactly what I have then I can get going on this project....
Thanks for the help.
-e
It is.
EN (or EJ maybe for you guys in the states) head is also very similar to EB3 head as far as valves and ports go.
So i was right about the year of the EB3 block. You guys have nade me smarter then th WHOLE WIDE WORLD. This place is an overwhelmig plethera of knowladge. I love it.
Godspeed.
A.W.
The way to spot the difference between EN and EB heads is that the EB head has a threaded mount on the other end to the timing belt for the torque rod. The EN had the torque rod go to a gear box mount. It won't be an EJ because that is a non-crossflow head. And since ENs were not avail in the states (only Canada) it is unlikely it is an EN head.
I would say it is the EB3 head as you presumed.
You know, I just had an idea.
Depending on available space, Richard, how about a "spotters guide"?
Perhaps moderate sized pictures and descriptions.
