Vacuum Line Nightmare!!!!!!!! Please Help
First Generation Civic Discussion Board: First Generation Civic Discussion Board: Vacuum Line Nightmare!!!!!!!! Please Help
Top of pagePrevious messageNext messageBottom of pageLink to this message   By A.W. (165.247.172.73) on Sunday, February 25, 2001 - 10:25 am:
Hi guys. I have a 81 Civic 1300. From the looks of it The vacuum lines are exactly upside down coming out of the control #1. I was woundering if ant one ha a vacuum line routing diagram? It is a 4spd, U.S. modile. I have the diagram under the hood but it dosnt day exactly what the lines going to the carb go to.If any one has this or could help please let me know. Either post it or if you have a diagram please email it to me.
Thanks and Godspeed,
A.W.
awcorr@mindspring.com
Top of pagePrevious messageNext messageBottom of pageLink to this message   By errol (152.163.204.189) on Sunday, February 25, 2001 - 10:28 pm:
I'll see if i can dig up some diagrams.... do you hav a fax???
Top of pagePrevious messageNext messageBottom of pageLink to this message   By A.W. (165.247.172.147) on Monday, February 26, 2001 - 02:31 pm:
Sorry no fax. Dont worry about it. This sunay i was able to determan that the line are right. Let me tell you the problem and see if any one may know. There is a vasuum line that goes to the throttle opener diaphram from the control box #1. OK this line is currently unhooked. When i connect the line and give it a little throttle the car revs way up and stays there untill i turn the car off or unhooh the line. In my routing diagram on the hood that vacuum line is coming from the control valve with dashpot check valve. Witch is located inside control box #1. Is it possible that this valve is bad and once it builds vacuum it cant release it unless the lin is unhooked? I ca unhook any other lines from this valce and nothing changes unless its the line that is building the vacuum or the line that goes to the diaphram.
Thanks for any help anyone could give and Godspeed to all,
A.W.
