RS differences
First Generation Civic Discussion Board: First Generation Civic Discussion Board: RS differences
Top of pagePrevious messageNext messageBottom of pageLink to this message   By david (208.130.247.47) on Saturday, March 03, 2001 - 01:45 am:
what were the mods on the RS model of the civic in comparison to a standard?
what block the RS's were based off?(eb1,2)
was there any boring, bigger pistons, diff. rods, etc?
any head differences?
what was the cam's specs?
any suspention/brakes upgrades?
any other apperence diffs?
what kind of hp did it get? C/R?
what kind of gas milage(on a well tuned engine, of course)?
any info any of you have would be helpful.
i'm thinking of bassically turing my car into an RS.
my logic is that honda knew best what would help performace with their cars, yet not sacrificing reliability and ecomomy(too much).
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Don (209.181.52.68) on Saturday, March 03, 2001 - 06:53 am:
http://sb1.honda-perf.org/rsweb/index.htm
Eric would probably know the anwers!
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Anonymous (208.60.186.113) on Saturday, March 03, 2001 - 10:22 am:
I have a set of the RS carbs, I bought them from some one off this board a year ago. They ran on the car but leaked around the filter base because a bolt hole in the upper shell of one o' the carbs is stripped out. If anyone wants them they're posted in the for sale section.
Top of pagePrevious messageNext messageBottom of pageLink to this message   By david (208.130.247.111) on Sunday, March 04, 2001 - 06:37 pm:
well, i talked to eric and he basically confirmed what i had already thought plus a few appearence things that i didn't. he didn't know anything about the cam specs, though.
in reading some threads i have found 2 diiferent answer to this question:
stock hight and 5 degrees longer duration than stock
and
stock hight and 15 degrees longer duration
which one is correct? the 5 degree sounds more hondalike to me.
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Todd (63.52.4.15) on Monday, March 05, 2001 - 04:28 am:
The thread I posted with cam specs came directly from our Japanese friend Tsuyoshi, so I assume it to be correct. You should e-mail him with all your RS questions. He does still have one after all. His English is very good and he is very helpful.
Top of pagePrevious messageNext messageBottom of pageLink to this message   By david (208.130.240.31) on Monday, March 05, 2001 - 10:40 am:
i already have and he said that he'd delve into the RS depths in a few days.
Top of pagePrevious messageNext messageBottom of pageLink to this message   By david (208.130.245.124) on Thursday, March 08, 2001 - 10:29 am:
well, here ALL the RS info i've colllected to date. if anyone has an corrections od additions that would be much apperciated...
RS
Engine:
block: eb1 -1169cc
piston: convex crown
Rods: stock
*strenthened crank bearing
*strenthened big end metal bearing
head: eb3 -36mm INTAKE, 32mm EXHAUST
Cam: stock height(IN-36.7mm, EX-36.6mm) and 15 degrees longer than standard.
max. valve lift: 8.6mm
Honda cam spec is always defined at 1.0 mm valve lift
INTAKE- open: 5 ATDC
close: 30 ABDC
EXHAUST- open: 40 BBDC
close: 5 BTDC
compression ratio: 8.6:1
suspention/brakes:
springs: 30% harder than standard - front - 2.5kg/mm
rear - 2.1kg/mm
shocks: harder shocks thand standard - comp. - 20kg
ten. - 60kg(at 0.3mm/sec)
wheels: 13", 4.5J
tire: 155-SR-82-13
RS strut casting is unopenable
-info from tsuyoshi hashimoto
offical honda specs:
Format: HONDA SBI
Total length(m): 3.65
Full-width(m): 1.505
Total height(m): 1.32
Wheel base(m): 2.2
Before tread(m): 1.305
After tread(m): 1.285
Roadspace(m): 0.165
Vehicle weight(kg): 695
Riding in a car fixed capacity(name): 5
Interior dimensions of body(m): Length 1.7
Width 1.27
Height 1.115
Engine: Water cooling
serial 4 cylinder
horizontal ranging (unleaded gasoline use)
Carburetor: 2 CV types(keihen)
Entire aerodynamic volume displacement(cm3): 1,169cc
Inside diameter x distance(mm): 70.0 X 76.0
Compression ratio: 8.6
The highest output(Ps/rpm): 76/6000
Largest torque(KG-M/RPM): 10.3/4000
Full speed(km/h): 160 (presumption)
Gradeability(TAN xdth): 0.46
Fuel economy: 23 KM/L -at the time of official test
value & pavement even path 60 km/h
Minimum turning radius(m): 4.7
At the time of braking stop distance(m): 13.5 -initial velocity 50km/h
Largest stable inclined angle (left and right): 50
Fuel pump format: Diaphragm type
Fuel tank capacity(L): 38 -Regular gasoline
Lubricating mode: Force system
Oil tank capacity(L): 3
Clutch format: Dry veneer diaphragm type
Transmission format: Advance 5 step full synchronizer (regular gearing system)
Transmission operation mode: Floor change system
Change gear ratio 1st gear 3
2nd gear 1.789
3rd gear 1.182
4th gear 0.846
5 speeds 0.714
Retreat 2.916
Leader format: Rack & pinion system
Tire size (also front and back) 155 S R13 (radial tire)
Type format of main brake: Before- Hydraulic type disk
After- Hydraulic leading trailing
Suspension mode (also front and back):
Strut mode independent suspension
appearance:
I have only seen either orange or warm red/orange RS's - never any other colour.
Stock Honda wheels were the black ones with red Honda abadge (actual start of red Honda "H")
and w/ polished steel lips on those rims.
RS badge on front grille on right attached with clips
on trunk where the later ones have the "Hondamatic" or "5speed" badge
on the dash where the later cars have the "CVCC" one
RS has instrument cluster with tach graded to 7k rpm.
Center auxiliary pod has two gauges AND an air vent where the
US deluxe ones merely had the two guages for fuel and temp.
Wooden steering wheel
Black vinyl interior
RS stands for "Road Sailing"
Top of pagePrevious messageNext messageBottom of pageLink to this message   By david (208.130.245.124) on Thursday, March 08, 2001 - 10:32 am:
i forgot to mention that in japan there was a GL civic too, which was inbeteen the standard and the RS. if anyone wants i'll post its diffs too.
