i wasn't sure if there were any hondas left in the world with disc rotors 9mm or thicker. this is what i need for my car to pass roadworthy. its funny though, i had the same discs (8.5mm) pass a rw 6 months ago, but this time i am getting it done at a brake and muffler shop. bad idea? the wreckers supplied me with 10mm thick rotors for $33 each (with hub cos it's too much work to press them out). i go to put them on today and they didn't fit too well - off a bloody accord.
but after measuring the remaining hondas at the yard , i found 3 rotors with 10mm - one with bodgy wheel bearings...
the two that are good are on a 4door 1500. will this all be the same? i have to pull these myself, and then put some of mine back on, as the prick reckons i got too good a deal to start with, and he wants the car to be able to drive still. whatever.
anyone know what thickness their rotors are?
i had, 7.5mm - 8.5mm - 8.5mm
They are 10mm factory and 9mm is the wear limit, mine are 24mm J
1200 and 1500 brakes are basically the same. The capilers are slightly different (use different shaped pads) but they are interchangable. Rotors, drive flanges and uprights are the same.
Charles are those disks the same as the one's you have on your website, cos it says 22mm thick.
