Brake Master Cylinder
First Generation Civic Discussion Board: First Generation Civic Discussion Board: Brake Master Cylinder
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Jacob (128.193.44.95) on Monday, April 16, 2001 - 07:22 pm:
http://cgi.ebay.com/ebaymotors/aw-cgi/ebayISAPI.dll?ViewItem&item=580590216&r=0&t=0
Will this fit a '76 Civic 1200? I would imagine it would take a little less pedal effort (not that there's any to begin with).
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Don (209.181.52.63) on Tuesday, April 17, 2001 - 06:14 pm:
The bigger the M/C bore, the more effort, but less travel required. In other words this M/C with its 16th" bigger bore will require more muscle but you will move the pedal less distance, better if your a midget on steroids. :)
This can always be offset by using a different size piston on the cylinders or caliper. How much work do you want to cause yourself? It may be a good purchase if you where going to use the USA wagon front brakes.
