1300 stroker
First Generation Civic Discussion Board: First Generation Civic Discussion Board: 1300 stroker
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Jacob (24.12.161.208) on Monday, May 21, 2001 - 11:33 am:
I was under the impression that the 1300 crank/rods that are used to stroke the 1200 were out of the EB3 block. I got an e-mail that made me think that they are actually out a CVCC, what is the motor code for this motor.
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Richard Nasr (Admin) (216.232.79.145) on Tuesday, May 22, 2001 - 02:44 pm:
I'm not replying to your message... sorry... just testing if the board is fixed...
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Adrian (Civicguru) (203.42.97.227) on Tuesday, May 22, 2001 - 03:54 pm:
EB1/2/3 all have the same stroke (76mm). What you want is the crank and rods from an EN1 (2nd gen. 80-83 model Civic).
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Charles (137.219.16.107) on Tuesday, May 22, 2001 - 04:46 pm:
If you are from the states they are from the EJ 1335 cvcc engine.
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Paul (202.27.182.225) on Tuesday, August 07, 2001 - 05:51 pm:
Can the 1300 rods be put straight into my EB3? With stock everything else?
Top of pagePrevious messageNext messageBottom of pageLink to this message   By quikrick (63.204.16.66) on Tuesday, August 07, 2001 - 07:49 pm:
Think about it... the 1300 has a longer stroke, hence shorter connectin rods. So if you use the rods from a 1300 without the matching crank shaft... your'e gonna have a little problem.
Top of pagePrevious messageNext messageBottom of pageLink to this message   By errol (64.12.106.48) on Tuesday, August 07, 2001 - 10:39 pm:
Hey kids, The stroker that i have has the '80 pistons also. this aids in pin hight. and also has a dome (slight.. but yes a dome!)
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Paul (203.96.100.95) on Tuesday, August 07, 2001 - 11:11 pm:
Yea, sorry I meant the 1300 rods and crank in my stock EB3....Will it work fine?
Top of pagePrevious messageNext messageBottom of pageLink to this message   By errol (205.188.195.145) on Wednesday, August 08, 2001 - 09:44 pm:
that's the way mine was, so...YES And i also had the 1300 pistons. If you want them they're for sale. They are a .25mm over, used but still good. 50.00 plus shipping. e
