Blown head gasket - or is it??
First Generation Civic Discussion Board: First Generation Civic Discussion Board: Blown head gasket - or is it??
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Paul (203.96.111.201) on Tuesday, May 22, 2001 - 12:56 am:
Hi guys, firstly if you could respond to this via email it would be helpful, as sometimes I cannot read all the posts - figliola@xtra.co.nz . I believe Richard is having some problems with the board, Good luck with that Richard.
Ok, there are a couple of us here in New Zealand who have noticed that grey whitish oil under the oil cap and on the walls on the rocker cover. However I have spoken to the other person about this, they have not blown the head gasket, and I don't think that I have because I have not noticed any other symptoms (Bubbling water, smoke, etc.) Can you help us fix the problem? I am going to do an oil change, just don't want to have to repeat this all the time I find the same grey oil.
Thanks all
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Jonathan Bailey (155.212.222.21) on Thursday, May 24, 2001 - 01:59 pm:
I would be very careful if I were you for anti-freeze and engine oil don't mix, (found out first hand!). One good thing about the whole situation is that I recived a chance To hand work my whole engine (this would be my first time, on a rebuild).
The enigine is starting to look nice and clean and I'm polishing the intake and exsaust ports and sanding the vales to a smooth finish (not too smooth, like a golf ball???) making them a tad bit smaller in the process. Every thing should be stock ex. for the hand work and the 1300 crank and rods.
I would have wrote an e-mail but I haven't had an address in six mounths.
If you don't know about combustion chamber compresstion testing using a gauge find out and do It soon or there will be no Civic.
I've been there too! You don't want to end up diving a ford tempo like I did.
I've moved on from tempo to pontiac 6000 (2.8mpfi ooh!!) I also have a beater 85 CRX witch is falling apart.
anyway you prably don't care any more
ANYWAY good luck!
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Travis (24.4.254.128) on Thursday, May 24, 2001 - 09:52 pm:
Hehe Hay I drive a tempo too. While my civic is being built (by me of course). But hay it's fun... I lowered it about 4-5"... LOL... it is crazy.
