Hi there guys,
I was browsing the net and found this company which might intrest some of you in the States, or maybe Canada??
http://www.anbolt.com/manufacturing-wheel_adapters.htm
Yes, there are many companies out there that will make hub adapters for pretty cheap.
Travis
I e-mailed them and was quoted $69 each. If you look in mini truckin, that sell sets (4) in there custom made to your size for about $50. Solid aluminum. Options....
Isn't it true that using adapters or spacers gives your bearings (and probably the rest of the suspension) all different kinds of assymetrical loads to deal with, and so making them wear faster?? This is what I have been told and it makes sense. Or is it not enough to worry about? I would like to consider these adapters for the rear, as an easy way to go to 100PCD... The front just needs bigger brakes for me.
