Does anybody know any trick to removing the control arm pivot bolt.
A multitude of cuss words seems to help...I have also used a cutoff wheel mounted on a flexible shaft to cut them off. Wouldn't happen so often if people would use anti seize on the bolts(liberally).
Thanks John S. A multitude of cuss words did help. Also a hacksaw,drill and sweat.
I find that a multitude of cuss words applied with equal amounts of WD-40, knuckle skin and blood seems to remove most frozen parts from cars.
We put the front on Jackstands with wheels pulled. Then used a hydrolic Jack to lift the rotors. Finally popping it off with a crowbar and wedge. Goodluck, they can be a !
