Straightening out Carb/Intake stuff
First Generation Civic Discussion Board: First Generation Civic Discussion Board: Straightening out Carb/Intake stuff
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Jacob (208.147.86.165) on Wednesday, September 12, 2001 - 04:20 pm:
OK, I've been looking for a Cannon Intake to Fit a Weber DCOE. I've discovered Weber Carb's with codes: DCOE, DCOM, DCO2, DCO3, and maybe a couple others I can't recall right now, are these all compatible with the DCOE intake?
Also I've discovered Mikuni and Dellorto make carburetors that fit the same intake manifold.
The Mikuni is the PHH, are there any other Mikuni's that fit this intake?
And the Dellorto is the DHLA, are there any other Dellorto Carb's that will fit this intake?
Also, is Cannon the only company that made an intake for the 1200, for the DCOE style carb's.
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Don (209.181.52.77) on Wednesday, September 12, 2001 - 07:19 pm:
There is also a side draft called a SK that has the same pattern. They are supposed to have had the best features of all the side drafts copied into one. A few have turned up on E-bay.
Mikuni's have more external adjustments than the Webers. Dellortos work, but seem to be more finicky than the others in my experience. I would guess that the DCO# will fit but the must be real old. Remember when buying old carbs that the Dichromate coating can some time disappear with age and use. This not only looks ugly but the corrosion causes problems in the small circuits.
Top of pagePrevious messageNext messageBottom of pageLink to this message   By Don (209.181.52.57) on Wednesday, September 12, 2001 - 09:26 pm:
CACI made an 1200 side draft intake too, or so I've heard.
