![]() | Adjustable Timing Gears | 18 | 12/11 10:10pm |
Everyone seems to be stroking their 1200's. Why not just use a 1300(EN1) block with a 1200 head. Is there something that doesn't make this possible or is the 1200 block better\stronger than the 1300.
'cause we aint got no EN engines down here in the US!
But BOY o BOY I wish I could get some of the non cvcc heads from Canada
hey errol ..
since i'm in canada ..
what exactly do you want me to look for?
mo
i'd like a non cvcc head if they're easy to come by up there. i suppose i'd need manifolds too. if anyone has one (core is fine) i'll make it worth their while. this would be for a '75 1500. my love-hate relationship with cvcc's is leaning towards hate these days.
Mo, What i'm looking for is the Canadian version head and intake for the 1500 78-83years and the same for the I think it's the 1602 that bolts on the US EK 1751 blocks (the space between cylinders 2-3 is about 3/8" instead of 1/2")
And all should be the 4port exhaust design please
'That's all' heheh
what is the best formula for the eb3 stroker
from the experienced honda doctors of hp
because i have two eb3 engines and 5spd
trannies, so i am going to drive one and build the other than swap it
what is the largest cfmi in a honda carb (just one carb) to install on my stroker for a final
good note. will a weber carb off a 2l. be to
much(ie. 2l. doch from a lancia beta)
adrian from calgary
new visto email ( goodvibes1@visto.com )
0
i have a 77 with a 1200 and i added a 5-speed toit.. i just blew the motor and need toget it running as soon as possible.. any thing i can find in a crate from japan??? with little to no mods? i know the early accord and prelude fit but can only find cores... thanx
Wow, Robb I don't know of any other Honda carbs that'll fit a 1200. The ones I usually swap are the early accord ones to the 1500's (but that's the cvcc engines)
Cal- Adrian, I'm taking the eb2 block to the machine shop tomorrow with a set of std. 1500 pistons. I'll have those pressed on a set fo 1300 rods and attached to a 1300 (US EJ) crank. I lightened a 1500 flywheel last week and need to see if it fits that 1300 crank. It's costing 125.00 US to balance the rotating assy.
