alright, when i got my 78 1200 it did not have a windshield wiper fluid system - no tubes, no sprayers, no reservoir. anyway, so i went to the junkyard, and acquired all of it. i put it in. so now i have a windshield washer. but where the hell is the reservoir supposed to go? it was plugged into the right wiring harness when i pulled it, so it wasn't hard to hook it up in my car, and it works fine, but the reservoir was laying on the battery tray when i found it and i couldn't figure out where it's suppossed to go so it's kinda resting on the brake system right now. where is it supposed to go?
I assume you got one of the bag types (the correct one). There should be 2 holes in the flap at the top of the bag. The proper battery holddown bracket has 2 tabs that you poke through these holes and the bag sits against the battery.
I hate those pee pee bag things. If your 78 is like mine you will have a plastic bottle that goes behind the left headlight. It mounts on a v shaped bracket that you might be missing. The bracket mounts inside the left fender wall right behind the headlight with 2 bolts and your bottle should slide right into it. You can see mine in this older picture. Its the white plastic bottle that you see in the top left corner of the picture.
oh. i pulled it off a 77? i think. it's a "pee pee bag" as you may put it.
alright, so where in the hell might i find the proper battery hold down?
Try the dealer!!! i picked up two they were around $11.00 each!!! Hey Jim u can only use the stock washer bottles if u have the room!! try puttin one of them in if u have a crx or integra motor..hehehe
Or a city turbo motor at that....u know how much crap they come with?. By the way the standard clips snap off easily
is the standard hold-down plastic or metal?
It is plastic covered metal.
Yes, the bracket is a plastic-covered metal. It goes across the top of the battery and I painted mine bright orange because it was all rusted up and the plasic was 90% already mising. I was pulling parts off of a '77 wagon, and I *think* it had the bag and bracket system...
I had one of those brackets but it slipped into my radiatior fan so i recomend the bottle over the pee pee bag anyday
Becks, That is hilarious. My battery hold down hook arm once fell into the radiator fan also. It made such a racket that I thought something really really bad happend! Just a lot of noise.
Anyone tried putting pee in that bag? I've heard that it makes a great window cleaning agent. Takes off all that road grime and scum no problem...
I'm going to hunt for that plastic bottle. Never liked the look of the bag.
lol well froma female prospective im not even goin there anony. Yea i thought my accelirator was stuck but nope it was only the damn hold down. I now use a newer model civic bottle and it does the trick a gem
