EK1 transmission question
First Generation Civic Discussion Board: First Generation Civic Discussion Board: EK1 transmission question
Top of pagePrevious messageNext messageBottom of pageLink to this message   By sean (24.184.163.233) on Monday, January 21, 2002 - 02:13 pm:
What 5-speed transmissions are there other than the stock one that will bolt to an EK1 engine? I want to build one up but the stock 5-speed doesn't have much of an overdrive gear and is very annoying on the highway, I need something that will keep the revs low to save my ears and gas.
Top of pagePrevious messageNext messageBottom of pageLink to this message   By dennis singley (65.101.2.229) on Monday, January 21, 2002 - 06:28 pm:
My 1980 1300 dx 5 speed trans bolts up to the EK-1 block. I believe its a GJ trans. It has overdrive in 4th & 5th gears & the final drive ratio is 4.933:1. I had to have the 1300 flywheel machined to fit the crank though. Had to open up both the bolt holes & the recess for the crank.
