I have just put on a weber carby with a redline air filter that is obviously different to the original air filter. Should I plug up the hole on the rocca cover that used to have a hose going to the air filter cover?
Don't plug that up, it will just blow the plug off anyway. Modify your air cleaner to fit a pick up tube or run a tube from the valve cover to a catch can. The charcoal canister mount is a good place to hold a catch can
Ramon, and others, i plan to put on a 32-36 this spring, when installing should you just gut all the other carb conections except the main inlet?
thanks,
kelly
I removed my carb, hoses, and smog box all comected and packed it in a box for smog inspections. I would also add a presure regulator.
