Does anyone know where the plug that you plug the neutral safety switch wire harness into after convreting form an auto to a stick is? 2low said that it was behind the fuse box, but to get in there I would have to remove the dash cover, and I don't want to do that.
Once you take out the automatic shifter, look for the very large gauge wire that is connected to the shifter. Simply tug on those wire a bit and see where under the dash it rattles. You should be able to reach it without major surgery.
Tony , the harness is behind the glove box in the upper right corner( u don't have to pull anything apart to get at it) just look under the dash for the connectors ....Justin
I recently converted from the matic to manual and just cut the wires shorted and reconected gear selector switch and mounted under dash. makes a cheap cull switch since i have no steering lock. Just push it of centre and she aint goin nowhere
