1stgen D16A3 swap 1978 Honda Civic CVCC
Gregoyo1
Province/State: Tolleson AZ
Post by Gregoyo1 »
I hot water pressure washed the D16 last week.
Im doing the engine bay this thursday (Much needed)
Nice!
Gregoyo1
Post by Gregoyo1 »
Its clear now I have alot on my plate.
-More wiring! (not as bad)
-Cutting and grinding (Dang I even have to grind off the battery trey!)
-Make mounts and brakets
-Make axles
-Shift linkage
-Cleaning and painting the engine bay,
-Fuel plumbing
I dont even know how I'm gonna get the ehaust down pipe over the front cross member..
But, in the end its all worth it!!
Layspeed
Zen Nos
Zen Nos
Province/State: Alberta
Hometown: Edmonton
Model: 1978 Wagon CVCC
Post by Layspeed »
on my swaps i actually found that the shift stabilizer bar was helpful in the positioning of the engine. It didn't need any modifications whatsoever, only the shift rod itself needed to be lengthened a bit iirc. For the exhaust, there are two options. 1st is to find an hf, cx, hx civic manifold and basically weld your exhaust downpipe to it and curve it out between the crossmember and front valence. Justin did this on his wagon and so did I on my 76. 2nd option is to make up a new crossmember or modify the existing one for clearance. I helped my cousin (jsvteck) modify his. He should have a picture of it, hopefully he reads this and can post one. Tip, something I found to be extremely useful was to make the shift rod adjustable. I just welded a threaded rod and sleeve into the actual shift rod so I can always adjust the 'neutral' position of my shifter to my liking. Let me know if that makes sense as I'm typing on my phone's tiny screen and my head is about to explode. My son took over my laptop and playing Call of Duty LOL!
Gregoyo1
Post by Gregoyo1 »
Thanks lay,
Those are some great tips, I will utilize them for sure. Especially the adjustable shift linkage.
Hey will the shifter bolt right into the cock pit as well?
Layspeed
Zen Nos
Zen Nos
Hometown: Edmonton
Post by Layspeed »
I think Randy or someone modified a newer Honda shifter to work, but I'm still using the Civic's stock shifter. Works fine for me. I just shortened it about an inch, which I shouldn't have cuz now it's a little short :lol:
Gregoyo1
Post by Gregoyo1 »
Alright.
This weekend i pulled the interior and did a little wire deleting and tucking. Now i have the dash a harness re assembled minus ac and heater for easy access.
Gregoyo1
Post by Gregoyo1 »
I have my pre made integra harness laying a bit in place and it looks comfortable. Tmro i will be doing some engine bay grinding to fit the D16A1 for mounting. Do i need to grind off the tq rod tower?
Gregoyo1
Post by Gregoyo1 »
Any tips or info will be greatly appriciated. (Lay) (Justin) :)
