Finding Parts Leaking Heater Control Valve 1976 Civic
- chiwat
- Province/State: Missouri
- Hometown: Moutain Grove
- Model: 1976 Hatchback CVCC
Does anyone know where I could get a heater control valve for a 1976 Honda Civic CVCC or know of a alternative to the factory heater control valve?
- Province/State: Oregon
Re: Leaking Heater Control Valve 1976 Civic
Try PartDeal.com under HVAC bottom of page.
- Province/State: SA
- Model: 1975 Hatchback
I'm probably a few too many months late to the party. I spent hours browsing classic cars for something that looked similar. I ended up finding a datsun 1200 heater control valve, which i've installed on mine and it works well. I needed to fit a reducer hose which I found off no-links. The top plate part of the civic valve is still good, but you will need to file it a bit. Swap the datsun top for the civic one (screwdriver and pliers get the job done).
Part number and example of part:
Hose reducer : Aeroflow Silicone Hose Reducer 45/64" - 1/2" 16-13mm I.D Black AF9201-070-050
Hope this helps!
Hope this helps!
