Keihin Gasket Kit
Induction Options, 1200 Build Up part 1, Performance Parts, Fuel System
diogonike
Keihin Gasket Kit
Post by diogonike »
Hello everyone
I recently bought a set of Keihin carburetors
I'm having some trouble finding the gasket repair kit
Did you have the same problem?
Can you help me
Thank you
amifsud
Keihin
Post by amifsud »
Look for Honda Goldwing GL1100 rebuild kits. Most of the bits should be the same.
diogonike
Keihin
Post by diogonike »
amifsud wrote:
September 9th, 2018, 10:03 pm
Hello
Thanks for the answer
It is similar, it is not the same, there are several differences, the diaphragm is different has a pin
diogonike
Keihin
Post by diogonike »
Hello everyone.
After much research, I was able to discover a company that has a repair kit that is similar and that you can take advantage of some of the parts to be able to repair the carburetors and substitute some of the parts that are spoiling as is the case of FUEL ENRICHMENT DIAPHRAGM
I already tried to contact the company, but I could not get any answers
The company is called Walker is headquartered in the United States, someone could help me
Keihin
There is one on
diogonike
Keihin
Post by diogonike »
Randy wrote:
September 24th, 2018, 8:54 am
Hello Mr. Randy
Thank you in advance for your help.
Yes, I also had the opportunity to see.
The kit that is available is not the same, but some of the parts that are available in the kit, give to my carburetor.
That's why I wanted to be able to talk to the walker company, in order to buy only the parts I need and not the complete kit.
Best Regards
tviracing
Province/State: London
Keihin
Post by tviracing »
hi diogo
i havent forgottn about you just no luck as we need these kits to
walkers is an american company and to me it seems strange for them to make a kit for a carburettor set that was not available in th usa ???
ive bought two walker kits for different carburettor and nothing fitted expensive waste of time!!
i,d look closer to home and to countries that sold the model of cars the carburettors came off of
diogonike
Keihin
Post by diogonike »
tviracing wrote:
September 27th, 2018, 9:09 am
hi diogo
Hello Mr. Slim
Yes it's actually a bit strange, but the truth is they make a kit that is similar, it's not the same but apparently you can take advantage of some of the pieces.
It is not easy to find, now I do not know what to do, it will be a waste of time, is not it worth trying to get this repair kit?
Am I the only one with the same problem? why there is so little information on the carburetor model?
