HondaCarCare1
Province/State: Portland Oregon, USA
Post by HondaCarCare1 »
Make sure you turn the "N" right-side-up before you install it back on the car. :lol: :wink:
Nice work! :D
islander
Province/State: Shawnigan Lake, British Columbia
Post by islander »
No I wouldn't suggest "panel painting" with a metallic colour. You will run into colour differences for sure. The next step once I move into my new house is to pull all the panels back off, pull the motor, and start the body work on the shell. As far as the HONDA letters and the N being the right way up.... well I have put them on allready, I just double checked and I did put it on upside down :oops:
The Civic 29.jpg (5.42 KiB) Viewed 13680 times
Layspeed
PsychoCiv
PsychoCiv
Province/State: Alberta
Hometown: Edmonton
Model: 1978 Wagon CVCC
Post by Layspeed »
where's my magnifying glass! :lol: It looks right side up at that size... :D
'78 Civic Wagon : '91 CR-X Si : '99 Odyssey : '99 CR-V : '77 Civic Wagon : '03 Pilot :
islander
Post by islander »
:lol: :lol: :D :lol: like I said before im not a computer guy. some come out big and well others you need to pull out ur magnifying glass :roll:
islander
Post by islander »
well, I'm back at it... I have taken a long brake from my project since I moved into my new house.... so today was the day to start removing all of the finished panels again. Time to get the body ready for paint. many rust patches to deal with first tho :wink: picks to come
islander
Post by islander »
Still having problems getting my pics online here. rather frustrating to say the least. haven't got to the nasty rust yet, but the motor is out. All of the suspension in the front end has been stripped and re painted. struts, springs, lower control arms, brake calipers(new re-mand), front cross member, knuckles and hubs, fan and cage, and also drive shafts. A lot of tedious work but well worth the outcome. Cant wait to get my pics on here :roll:
Eduardo I. Nieves Davila
Province/State: Carolina PuertoRico
Post by Eduardo I. Nieves Davila »
Cool 8) will you usethe same engine?
Every old honda deserves a second chance.
islander
Post by islander »
ya, I've decided to stick with the same engine. I have it fully stripped down just to the head still attached to the block. I noticed one of the intake valves not fully seating so until I do a leak test on the motor I'm not sure how much further I will go. if it's the rings also leaking then all bearings and rings as well as a valve grind will get done I guess. Cant wait to get my pics on to show everyone.
islander
Post by islander »
:D :D Got the picture thing figured woo!! Here we go with some up dates.
Worn timing chain cover. Junk
My old calipers I tried to fix up, until I found out you can buy re-mand ones for cheep. but this is what they will look like
Hubs all re painted
Hubs all re painted
Drive shafts
Drive shafts
lower control arm
lower control arm
front control arms and sway bar
valve cover removed. looks very clean
islander
Post by islander »
got board, took some pics
whats left of the battery tray
