- Layspeed
- PsychoCiv
- Province/State: Alberta
- Hometown: Edmonton
- Model: 1978 Wagon CVCC
Fancy! And a great match to the faux wood dash trim 8) If you don't mind sharing, what process/materials did you use? Just curious.
'78 Civic Wagon : '91 CR-X Si : '99 Odyssey : '99 CR-V : '77 Civic Wagon : '03 Pilot :
- islander
- Province/State: Shawnigan Lake, British Columbia
Lay all I did was strip the wheel down, sanded the wood part with 180 grit. I noticed there were cracks in the wood. To repair this I simply used the wood dust that had been sanded in to the crack and coated over top of the crack with super glue. Once the glue was dried I sanded it smooth. Once the wheel was ready, I masked up the wood and based the center with silver. When the silver was dry, I un masked the wood and cleared the whole wheel. I did not apply any stain to the wood, the colour came just from the clear coat.
Every old car deserves a second chance!
- islander
Thanks Bob.
My pistons showed up today :D I just cant get over how fast they got here. I ordered them 4 days ago from New Zealand. They must be fast pistons Has anyone ever heard of this brand? Just wondering the quality. I mean the important thing is that they will fit my car, not looking for race performance out of this motor.
- DSC02765.JPG (125.47 KiB) Viewed 1141 times
- DSC02764.JPG (141.13 KiB) Viewed 1141 times
- DSC02763.JPG (128.76 KiB) Viewed 1141 times
That's the exact same set I have in my box of parts for my eventual rebuild, which I also bought from Chris. Don't know when I'll actually need to rebuild though, as the engine doesn't even blow any smoke when I thrash it, and that's running on 10W40 oil. Mine also have a dull finish, and I'm wondering if I should polish them up or not... Bill?
- islander
Thanks for asking that question about the dull finish Steph. I was wondering the same thing. All and all it seems to be a good response on the parts then. As far as I know all the machine shop has to do is find me one crank seal and everything else should be good to go. Also now that I have the pistons they can carry on with the bore on the cylinders.
