Re: Bob78CVCC Project
Finally have the stripes back on! :)
Civic Stripes - Black on Civic (600 x 337).jpg (56.29 KiB) Viewed 1492 times
rocco
Member
Member
Province/State: north GA
Post by rocco »
looks great Bob hope you r happy i know by experience how much you love your car.its a special bond only a special man can endure it was only slitely bruised not violated.i know how you feel mine got backed into bye a expedition at full bore and i will tell you mine won.your car is amazing and well done on the fix.
esolano
Owner
Owner
Post by esolano »
Bob, just wondering... where did you get the stripes from? Did you get them made?
esolano wrote:Bob, just wondering... where did you get the stripes from? Did you get them made?
Yes, I had them made locally from a vector file provided by stephan ( koosjer55 ) .
PM him for the file if you're interested. He will charge you $20 US for the file which you can provide to a local shop to make for you. :)
esolano
Owner
Owner
Post by esolano »
That's great thanks:)
Bob78CVCC Project
Finally got around to refinishing the outside of the tank I picked up from Jonathan.
There was a fair amount of surface rust particularly on the top of the tank.
viewtopic.php?t=8989&start=470
Gently sanded down the tank to remove and treat the metal and rust.
Primed it with gray color zero rust and sprayed it with black satin Rustoleum paint.
I'll cover the bottom of the tank with the same rubberized undercoat to match the rest of the car. :)
Gas Tank Primered_renamed_17870.jpg (58.87 KiB) Viewed 2235 times
Gas Tank Primered 2_renamed_4206.jpg (46.87 KiB) Viewed 2235 times
Gas Tank Primered 3_renamed_9172.jpg (51.5 KiB) Viewed 2235 times
Gas Tank 1_renamed_16702.jpg (41.92 KiB) Viewed 2235 times
Gas Tank 2_renamed_11641.jpg (51.14 KiB) Viewed 2235 times
The weather was nice enough to devote most of the day to working on the car.
The gas tank got swapped out and the parking brake cable was replaced.
Tomorrow, I'll put the interior back together.
Had to remove the center and upper console & back seat to replace the brake cable.
Had a very tough time removing the adjustment nut from the threaded portion of the cable.
It didn't help matters that the threaded rod was bent where the nut had to be removed.
The cable still needs to be adjusted. :)
Hoping to get the exhaust work done next week.
Will be replacing the B pipe and muffler.
Still need to rubberize the bottom of the tank to match the rest of the undercoat
or should I leave it as is? :)
Parking Brake Cable (600 x 501).jpg (65.56 KiB) Viewed 2225 times
Refinished Tank Install (600 x 431).jpg (79.82 KiB) Viewed 2225 times
New custom B Pipe and muffler installed.
I'll take some better pics when I get it all cleaned up. :)
Ansa Muffler 1 (600 x 298).jpg (35.1 KiB) Viewed 2208 times
Exhaust Pipe & Ansa (600 x 450).jpg (93.43 KiB) Viewed 2208 times
lookn' good :)
The car made the round trip to the 2013 Carlisle Import Show without incident.
I kept up with traffic but didn't push the throttle too hard as the engine is still being broken in.
Refinished or should I say practiced refinishing my spare shift knob.
The other knob should come out better. :)
Shift Knob a (600 x 422).jpg (49.91 KiB) Viewed 2189 times
Shift Knob b (600 x 534).jpg (58.69 KiB) Viewed 2189 times
Shift Knob c (600 x 450).jpg (57.82 KiB) Viewed 2189 times
Shift Knob d (600 x 450).jpg (77.4 KiB) Viewed 2189 times
Civic 5-25-13 c (600 x 318).jpg (43.21 KiB) Viewed 2189 times
