Project CrAzY_DrIveR 1978 Civic SB1 "IO"
CrAzY_DrIveR
Member
Member
Post by CrAzY_DrIveR »
When I went to get the car
Resting next to the E30
drag DR16 7j15 et40 195/50r15
my rear 4x100 conversion with crx disc brakes still waiting on the prelude calipers
the hub with disc sits 5mm more to the iside compaired to the drum
taking care of the front now
Last edited by CrAzY_DrIveR on April 23rd, 2017, 8:31 pm, edited 2 times in total.
:honda
Re: '78 Civic SB1 "IO"
I like the wheels, they look great.
the hub sits 5mm more to the iside compaired to the drum
So the rear CRX conversion doesn't stick out as much, not much of a difference.
Did you have to do any machining for the back CRX conversion to fit?
CrAzY_DrIveR
Member
Member
the hub and disc are the same as the civic i just followed the forum's tutorials :)
just a spacer on the back to center the disc to caliper and hold the back dust shield.
The front is really bad the wheel sticks out of the fender and can't go more inside :169
i will be using the crx bearing to be able to press the crx/civic front hub with a spacer behind the bearing and a custom top with 4 screws because the bearing is 6mm longer and i need the hub to go outwards.
Last edited by CrAzY_DrIveR on March 16th, 2017, 9:42 pm, edited 2 times in total.
:honda
CrAzY_DrIveR
Member
Member
yeah pretty normal for fwd cars
:honda
CrAzY_DrIveR
Member
Member
Front done, blasted and painted.
Now just have to put it back in!
:honda
CrAzY_DrIveR
Member
Member
CrAzY_DrIveR 1978 Civic SB1 "IO" Project
found this nice kamei spoiler air dam last week
:honda
