- koosjer55
- JDM
- Province/State: The Netherlands
Hello...is this thing on?
Yesterday I made a start with my project. It's a 1979 Civic 1200. I'm the second owner and I have the car for about 3 years now. It run approx. 95.000 km so far and runs still pretty smooth.
First of all I'm stripping the car down. Next week I'm taking the dash out and hopefully the engine as well. Since the car is at my grandpa's garage I'm not able to work on it through the week, but I'm not in a hurry.
Plans are:
- Restoring the engine (new high compression pistons, faster camshaft, RS exhaust manifold). Have a 5-speed transmission of a sec.gen. Civic and changing all the bearings and stuff like that.
- Welding some body-parts (have already new front fenders).
- Stiffer suspension (have CRX shocks, hopefully they work out right after some welding). Have Superpro poly bushings as well. Lower the car with a couple of centimeters, etc.
- Sanding the whole car and get it ready for paint. Not quite sure if I'll go for RS-orange or olive green..
Be right back.
Plans are:
Be right back.
- civic4.jpg (86.43 KiB) Viewed 15827 times
- civic3.jpg (99.29 KiB) Viewed 15827 times
- civic2.jpg (107.26 KiB) Viewed 15827 times
- civic1.jpg (76.5 KiB) Viewed 15827 times
- koosjer55
- JDM
- koosjer55
- JDM
day 3...and here we have some rust...
Couple of pics..
- This Saturday, day 4, only 1 pin of the gearshift rod and I can pull out the engine.
- civic11.jpg (120.34 KiB) Viewed 12095 times
- civic10.jpg (105.06 KiB) Viewed 12087 times
- civic9.jpg (104.16 KiB) Viewed 12086 times
- civic8.jpg (65.7 KiB) Viewed 12088 times
- civic7.jpg (106.43 KiB) Viewed 12090 times
- civic6.jpg (89.58 KiB) Viewed 12086 times
- After removing the front fenders I found what I already did expect...let me call my welder!
- civic5.jpg (92.38 KiB) Viewed 11950 times
- koosjer55
- JDM
day 4
Day 4 and the engine is out! Welding and sanding can be done soon, I hope (depends on my welder). What I want now is another tailgate, without rust. The one I have is reparable, but a rustfree one would safe me some time.
Update: next week
Update: next week
- civic14.jpg (105.71 KiB) Viewed 11950 times
- civic13.jpg (81.5 KiB) Viewed 11950 times
- civic12.jpg (112.17 KiB) Viewed 11950 times
- koosjer55
- JDM
It's been way too long since my last update. As we say it over here in Holland: I haven't been sitting still Let these pics do the talking.
- new lower skirt in place
- PB220544.jpg (87.56 KiB) Viewed 3040 times
- it fits and next time this part will be finised
- PB220557.jpg (66.32 KiB) Viewed 3040 times
- Rust all over the place...cutting and replacing is the only way
- PB220543.jpg (90.03 KiB) Viewed 3040 times
- P5100304.jpg (69.39 KiB) Viewed 3040 times
- My buddy Dennis is the dedicated welder and grinder!
- P5100303.jpg (100.62 KiB) Viewed 3040 times
- engine after..almost finished. Head is also "overhauled", as is the oilpump. RS carburetor are back on it soon. Electronic ignition is also on its way.
- PB220552.jpg (88.61 KiB) Viewed 3040 times
- painted black (and grind the Honda letters..simple trick!)
- P5100306.jpg (62.08 KiB) Viewed 3040 times
- P5300350.jpg (96.76 KiB) Viewed 3040 times
- back from the shop and venolia pistons are in
- P5230314.jpg (93.13 KiB) Viewed 3040 times
- engine before
- P2230207.jpg (104.01 KiB) Viewed 3040 times
- koosjer55
- JDM
and some more pics
- nice find!
- PB220555.jpg (58.7 KiB) Viewed 3035 times
- cleaned chassis parts and painted black with thick rust protecter. All moving parts have the Super Pro poly-bushings now.
- PB220548.jpg (67.45 KiB) Viewed 3035 times
- in the meantime I've refurbished the radiotor..now I'm this far, nothing escapes from refurbishing!
- P5230319.jpg (100.82 KiB) Viewed 3024 times
- koosjer55
- JDM
I did indeed replace all the bearings (in the 5-speed transmission as well). I buy almost everything via cmsnl.com. Engine parts are easy to get. The radiator paint is heat resistant paint from Motip. Should do the job. The fan has just been cleaned. I bought a standard used camshaft from somebody in Rotterdam. One day I'll probably replace it for a racing camshaft.
- koosjer55
- JDM
- koosjer55
- JDM
