Do you need Camber-Caster plates plates
Many Honda’s use McPherson struts, only one of the three alignment settings toe can be adjusted. For high performance use, the ability to adjust camber and caster is desirable as well, particularly on the front suspension. Camber-caster plates provide these adjustments, and usually replace the upper mounting and bushing at the top of the fender well where the strut rod is connected to the body.
Camber is the amount the top of the tire leans inward or outward in comparison to the bottom of the tire with the tires straight ahead. If the wheel leans inward at the top, it has negative camber. If it leans outward at the top, it has positive camber. The measurement is made in degrees and minutes.
