Suction Stroke
On the intake stroke, a large amount of very lean mixture is drawn through the main intake valve into the main combustion chamber. At the same time, a very small amount of rich mixture is drawn through the auxiliary intake valve into the pre-chamber. |
Compression Stroke
At the end of the compression stroke, a rich mixture is present in the pre-chamber, a moderate mixture is formed in the main combustion chamber near the pre-chamber outlet, and a very lean mixture is present in the remainder of the main combustion chamber. |
Ignition
When the spark plug fires, the rich mixture in the pre-chamber is easily ignited. |
Expansion Stroke
The flame from the pre-chamber ignites the moderate mixture and this, in turn, ignites the lean mixture in the main combustion chamber. The formation of carbon monoxide is minimized because of this lean mixture. |
Bottom Dead Center
The stable and slow burning in the main combustion chamber has two desired effects. The peak temperature stays low enough to minimize the formation of oxides of nitrogen. And the mean temperature is maintained high enough and long enough to substantially reduce hydrocarbon emissions. |
Exhaust Stroke
The hot gases exit through the exhaust valve, and oxidation continues in the manifold. |
