What are the differences between the eb2 and eb3 pistons? I can get a set of eb2 (.75) new for $50.00. If i were to use them in a eb3 block/head would it drop compression?
EB3 has a slight dome. EB2 does not. As you suspect, it will drop compression considerably.
HHHHHMMMMMM.... These are 'domed' but have a flat around the outer edge, about 1/8". I looked them up in a very old parts manual from federal mogule(?). and the part number figures out to be a EB2 because a EB3 shows a 'dome' all the way to the edge
the manual also showed that the 80 1300cvcc as a domed one also, but for only that year (?) But then those two EJ 1300's that i have both have flat-tops..... "Make it go away MOMMA"
A long time ago, I went to a machine shop that had a book with all the different piston profiles available. According to that book, there were SIX(!) different piston tops for the EJ1300 between '80 and '83. They ranged from a .050" sorta dome, to a .050" dish.
Sick, huh?
Charles R. So if i were to use those eb2 .075 over pistons on a ej 1300 rotating assembly and a eb3 head would it raise or lower compression?
It's just that they are a good price and in stock!
.075? That's not the oversize dia. is it? That's about 2mm,and that's VERY big for an EB2 engine.
If you're talking, boring the block .075" bigger and using a 1300 crank/rod set, you'll have nearly the same bottom end I have (mine's .080"dia.). The EB2 head will give you about 12:1, while the EB3 should be around 9:1. Displacement is a little over 1400cc's.
I think he has .75 mm over size pistons, not .075 inch. Wont this lower the forcasted Comp # by about a point?
has anyone had any experience with those crown convex pistons? the ones that came on the japanese RS's and GL's.
I have a RS/GL motor.
Cam And crank are shot..Bores are Ok.
One piston skirt is nicked,due to thrown rod.
Looking for a piston although I have been told I could dress the skirt and be Ok.
Don't know about that.
Anyone have anything let me know.
What is the difference between the RS/GL and the EB3 heads 70mm vs 72mm as far as combustion chamber volume ?
I currently run an EB2 .010 oversize pistons, Web #102 cam and Holly\Weber carb,balanced with lightened flywheel and custom tri-y header.
Runs like a "Raped Ape"
Anyway..What about oversize EB3 pistons with the EB2 block Rs/Gl head{Thinking there will be some compression gain}
Twin Dellorto DHLB 35 mm and Web #68 cam ?
Thoughts...Ideas ?
Bill
70mm bore for EB1, 72mm for EB2/3, not combustion chamber volume. I can't find where I have combustion chamber volumes recorded just at the moment, but from memory EB3 is somewhere around 36cc. EB1 RS and EB3 heads are very very similar. At a quick glance you can't really tell the ports and chambers apart.
"Anyway..What about oversize EB3 pistons with the EB2 block Rs/Gl head{Thinking there will be some compression gain}" - Block makes no difference (basically all the same). Using EB3 pistons with an RS head basically gives you an EB3. You will have no significant compression gain over a standard bore EB3 unless you skim the head a lot.
Errol,
my EB3 pistons are exactly as you describe 'These are 'domed' but have a flat around the outer edge, about 1/8".'
with 72 mm nominal bore. sounds like the pistons you are looking at are EB3 not EB2.
Hope this helps
John
