Items
Mileage Interval x 1,000 Miles
7.5 |
15 |
22.5 |
30 |
37.5 |
45 |
52.5
60
67.5 |
75
Engine
Valve Clearance
I |
I |
I |
I |
Alternator Drive Belt
I |
I |
Vacuum Fittings, Hoses &
Connections
I |
I |
I |
I |
Engine Oil
R |
R |
R |
R |
R |
R |
R |
R |
R |
R |
Engine oil Filter
R |
R |
R |
R |
R |
R |
R |
R |
R |
R |
Coolant
R |
R |
Cooling System, Hoses & Connections
I |
I |
Exterior of Radiator Core
C |
C |
C |
C |
Intake & Exhaust Manifold Tightness
Check
I |
I |
I |
I |
I |
I |
Radiator Fan
I |
I |
I |
Fuel System
Idle Speed & Idle CO
I |
Choke Mechanism
I |
Throttle Opener & Control Valve
I |
Air Cleaner Element
R |
R |
Fuel Filter & Hoses |
R |
Intake Air Temp. Control System
I |
Tank, Fuel Lines and Connections
I |
Evap. Emissions System
E.R.G. System (Cold)
I |
Two-Way Valve
I |
Thermovalve B (cold) |
I |
Ignition Components
Ignition Timing
I |
Ignition Timing Control |
I |
Spark Plugs
R |
R |
Distributor Cap and Rotor
I |
Ignition Wiring
I |
Crankcase Emission Control System |
I |
I |
Mileage Interval x 1,000 Miles |
7.5 |
15 |
22.5 |
30 |
37.5 |
45 |
52.5 |
60 |
67.5 |
75 |
Brakes
Rear Brake
I |
I |
I |
I |
I |
I |
Parking Brake
I |
I |
I |
Brake Hoses, Lines,
I |
I |
I |
I |
I |
I |
Master Cylinder, Fluid Level
I |
I |
Brake Fluid *
R |
R |
Front Brake Pads
I |
I |
I |
I |
I |
I |
I |
I |
I |
I |
Front Brake Caliper Performance
I |
I |
I |
I |
I |
I |
I |
I |
I |
I |
Rear Brake Linings
I |
I |
Other
Front Wheel Alignment
I |
I |
I |
I |
I |
Steering Rack Guides
I |
I |
I |
Steering operation, Tie Rod Ends
I |
I |
I |
Grease Steering Gear Box
I |
I |
I |
Engine Exhaust Silencer
I |
I |
I |
I |
I |
I |
Suspension Mounting Bolts
I |
I |
I |
I |
I |
I |
Rear Wheel Bearing Grease |
R |
Transmission |
7.5 |
15 |
22.5 |
30 |
37.5 |
45 |
50.5 |
60 |
67.5 |
75 |
Transmission Manual Oil |
R |
R |
Transmission Automatic Oil |
R |
R |
R |
Clutch Pedal Travel
I |
I |
I |
I |
I |
I |
I |
I |
I |
I |
A-ADJUST I-INSPECT, ADJUST OR REPLACE AS
NECESSARY R-REPLACE C-CLEAN
