What
is a 1500 Hatchback Civic
Dimensions |
Overall Length |
3,770mm |
148.4 in. |
Overall Width |
1,580mm |
62.2 in. |
Overall Height |
1,350mm |
53.2 in. |
Wheelbase |
2,250mm |
88.6 in. |
Track F/R |
1,360/1,380mm |
53.5/54.3 in. |
Ground Clearance |
165mm |
6.4 in. |
Overhang |
765/755mm |
30.1/29.7 in. |
Includes Bumper |
Weights |
Engine (wet) |
3-Speed |
170kg |
375 lb. |
Incl. Transmission |
5-Speed |
181kg |
399 lb. |
Curb Weight |
3-Speed |
857kg |
1,889 lb. |
5-Speed |
847kg |
1,867 lb. |
5-Speed (GL-S) |
861kg |
1,898 lb. |
Gross Weight |
1,261kg |
2,780 lb. |
Carrying Weight |
45kg |
100lb |
Capacities |
Engine |
Without Filter |
3L |
3.2 US qt. |
With Filter |
3.5L |
3.7 US qt. |
Transmission Man. |
Drain/Fill |
2.5L |
2.6 US qt. |
Initial Fill |
2.65L |
2.81 US qt. |
Automatic |
Drain/Fill |
2.5L |
2.6 US qt. |
Initial Fill |
4.9L |
5. US qt. |
Fuel Tank |
41L |
10.8 US gal. |
Cooling System |
Drain/Fill |
5.4/4.2L |
1.4/1.1 US gal. |
Reservoir Not Inc. |
Windshield |
2.0L |
2.1 US gal. |
Engine |
Engine Type |
EM1 |
Bore & Stroke |
74.0x86.5mm |
2.91x3.41 in. |
Displacement |
1,488cm3 |
91 cu. in. |
Compression Ratio |
9.3:1 |
max 9.5:1 |
min 9.1:1 |
Fuel |
Unleaded |
Transmission |
Clutch |
3-SP |
Torque Converter |
5-SP |
Single Plate Dry, diaphragm spring |
Transmission |
3-SP |
3fwd 1rev w/torque converter |
5-SP |
Synchronized 5fwd 1rev |
Primary Reduction |
Direct 1 : 1 |
Gear Ratio |
5-SP |
3-SP |
1st |
3.181 |
2.380 |
2nd |
1.823 |
1.500 |
3rd |
1.181 |
0.911 |
4th |
0.846 |
5th |
0.714 |
Reverse |
2.916 |
1.954 |
Final Reduction |
3-SP |
Single helical gear 3.588 |
5-SP |
Single helical gear 3.875 |
Steering |
Gear Type |
Rack & Pinion |
Steering Wheel |
385mm or 15" |
Suspension |
Front and rear Independent MacPherson strut hydraulic shock
absorber, coil spring
Brakes |
Front: Self adjusting power disc brake |
Rear: Power assisted drum brake |
Tires |
155SR13 |
(P165/70R13) |
