What
is a 1300 Hatchback Civic
Dimensions |
Overall Length |
3,770mm |
148.4 in. |
Overall Width |
1,580mm |
62.2 in. |
Overall Height |
1,350mm |
53.2 in. |
Wheelbase |
2,250mm |
88.6 in. |
Track F/R |
1,360/1,380mm |
53.5/54.3 in. |
Ground Clearance |
165mm |
6.4 in. |
Overhang |
765/755mm |
30.1/29.7 in. |
Includes Bumper |
Weights |
Engine (wet) |
4-Speed |
150kg |
331 lb. |
Incl. Transmission |
5-Speed |
150kg |
331 lb. |
Curb Weight |
4-Speed |
804kg |
1,773 lb. |
5-Speed |
818kg |
1,803 lb. |
Gross Weight |
1,181kg |
2,605 lb. |
Carrying Weight |
45kg |
100lb |
Capacities |
Engine |
Without Filter |
3L |
3.2 US qt. |
With Filter |
3.5L |
3.7 US qt. |
Transmission |
Drain/Fill |
2.5L |
2.6 US qt. |
Initial Fill 4-SP |
2.6L |
2.8 US qt. |
Initial Fill 5-SP |
2.65L |
2.81 US qt. |
Fuel Tank |
41L |
10.8 US gal. |
Cooling System |
Drain/Fill |
4.6/3.4L |
1.2/0.9 US gal. |
Reservoir Not Inc. |
Windshield |
2.0L |
2.1 US gal. |
Engine |
Engine Type |
EJ1 |
Bore & Stroke |
72.0x82.0mm |
2.83x3.23 in. |
Displacement |
1,335cm3 |
81 cu. in. |
Compression Ratio |
9.3:1 |
max 9.5:1 |
min 9.1:1 |
Fuel |
Unleaded |
Transmission |
Clutch |
3-SP |
Torque Converter |
4-SP/5-SP |
Single Plate Dry, diaphragm spring |
Transmission |
3-SP |
3fwd 1rev w/torque converter |
4-SP |
Synchronized 4fwd 1rev |
5-SP |
Synchronized 5fwd 1rev |
Primary Reduction |
Direct 1 : 1 |
Gear Ratio |
4-SP |
5-SP |
1st |
3.272 |
3.272 |
2nd |
1.666 |
1.666 |
3rd |
1.041 |
1.041 |
4th |
0.777 |
0.777 |
5th |
0.655 |
Reverse |
2.916 |
2.916 |
Final Reduction |
4-SP |
Single helical gear 4.066 |
5-SP |
Single helical gear 3.722 |
Steering |
Gear Type |
Rack & Pinion |
Steering Wheel |
385mm or 15" |
Suspension |
Front and rear Independent MacPherson strut hydraulic shock
absorber, coil spring
Brakes |
Front: Self adjusting power disc brake |
Rear: Power assisted drum brake |
Tires |
4-SP |
155SR12 |
5-SP |
P165/70R13 |
