Stereo Options
Mounting a standard deck?
Unfortunately when Honda designed
these cars they didn’t think too much about people wanting to replace the
factory AM/FM deck with something a little nicer.
Stock Honda Radios'
Honda/Pioneer AM/FM Cassette
Honda/Pioneer Cassette
Honda/Pioneer 8-Track tape deck
Typical stock Hitachi AM radio
Typical radio install kit.
Installation Instructions for the
Under dash speaker
Honda in dash Stereo 8-Track tape deck
Where to put it? 6 different solutions
1. Dremel out stock location and
fit deck in there
Pay special attention to the depth
required for your unit.
2. Under dash kit by American international part #HRH-420
www.americaninternational.net
3. Mount it in the glove box,
this might also be good security for a valuable unit
4. Mount it under the glove box.
Brian Wilborn used an aftermarket tray
and mounted his DIN sized unit under the glove compartment. Just drilled and
countersunk holes in the bottom of the glove compartment and used flathead
machine screws to attach the tray.
5. Find stereo that fits in the
stock location
Blaupunkt "micro chassis" is
what Justin’s using. it's a tape deck with digital display, it has 12 fm
and 6 am presets stereo output and also a 4 channel "din" plug
output
6. Find a floor console either OEM or aftermarket.
There are some examples on this site of Accord, CRX, etc.
Speakers
The first time you turned on that stock radio you wondered
where the sound was coming from, as if it was being piped through an old
soup can from under your dash. If you look on the drivers side under the
dash just below the access for the door hinge. There it is, shocking isn't
it. Well it's got to go. This is not even good enough to say stock. Rare
Honda roof liner speakers are expensive if you can find them. But the big
draw back is the lack of good quality sound. You would be better off to get
the Honda rear pocket speaker grilles and then you can start talking about
decent sound. Check out many of the examples below of how other members
mounted their speakers and systems.
Rear roof liner speakers
Rear side pocket grilles
Front wheel well speakers
Rear Deck
Rear side pockets
Cher's Civic
The subs are put in a fiberglass
enclosure that mimics the back seat and the grill is actually made from the
top cushion of '91 civic SI rear seat, the upper seat is gutted and the amp
rack is installed in it, the cover unzips to reveal the amps, the deck
is the same as Twyla's (alpine 1656sp) but it is installed in the stock
radio location.
Twyla's convertible
Her deck is a Alpine 1656sp. It's a
controller unit that is hooked up to a changer and is controlled via remote,
It has controls on the face as well, I re-routed them to the blanks where
the dimmer/choke controls go, so she can change tracks and control volume
from them. It has a external speaker input so you can hook up a factory
radio to get Am/Fm, and in her stock location I put in a old school alpine
micro chassis am/fm/cassette. I also have a alpine controller in my
wagon(1203) and it's in the aftermarket rear view mirror (behind two way
glass) you can only see it when the deck is turned on, I use a remote
control to control all of the functions, I wired up one of the mirror
switches (originally for the internal light) to control power and change the
illumination from white to orange. I'm currently building a new sound system
for the back.
Clock
Install overhead console for analog
style or use Justin option, a digital clock, it's from a 82'-85' accord, you
have to shave the back and sides down in order to get it to fit. If you are
lucky enough to find there was an optional clock from Honda for the dash.
Most new stereo's come with build in clocks if you can find on to fit.
Antenna
Hidden
Antenna
HIDE IT! Getting rid of your ugly
factory antenna is one of the quickest and cheapest ways to improve the
looks of your vehicle. AutoLoc's exclusive HAB Hidden Antenna offers all the
performance and quality FM reception of an external antenna without breaking
up the clean lines of your vehicle. Works as well as a standard antenna
(except for AM) but without the unsightly rod and mask.
Volkswagen
roof mount antenna (Billet
or Euro Style)
Forget about the stock antenna wire.
Just put in the Volkswagen roof mount (model# EA80 from Harada) and get a
coax extension. You could run it down the rear or down the widow post.
Haven't put one in a first generation yet. They are a powered (amplified)
antenna and work AWESOME! Especially since you get a far better ground plane
in the middle of a flatter sheet of metal.
Remember to order a long extension.
Don't try to slice modern coax the center conductor is like a strand of
hair. Also the power wire for the signal amp should run off acc power not
your blue amp trigger output. Or if you really want it right use a relay
triggered by the blue wire fed by acc power!
Dash removal
Ten bolts just for the dash. Two at
each end. One behind each air vent. Two, just above the steering column
(four more to drop the column). one in the "cubby hole" under the
heater controls and one in the back of the glove compartment. You'll need to
unscrew the speedometer cable from the gauge and undo the heater control
cables as well.
