First Generation Honda Civic 1973-1979 Suspension Menu
Index Page Tires Wheels Brake Mods Suspension Bushings Camber Castor Plates
Main Menu Strut ID Strut Mod VW Brake Mod Rear Suspension Choices Suspension Mod Article
 Suspension Choices
1st generation suspension
For the Gen 1 you have many choices suspension wise depending on what your needs are.
1- Where are you driving and what tires are you going to use?
Race compound street tires develop more grip and wear out in under 2000 miles. If you are going to use these tires to their fullest potential your suspension will have to be much different and much more $$$$ than someone that wants to enjoy a sporty ride just to and from work. also the oil pan will need work if you use the soft tires as its possible to starve the engine under high cornering force.
2- How much are you going to lower your Civic? The Civic has fairly good suspension geometry from the factory, but if you lower the car too much the design goes into the toilet. Roll center and bump steer along with camber really get bad when lowering over one inch . If you want to lower further be prepared to spend $$$ and time fixing these problems or you handling will be worse than if you left the car at a taller height. Also lowering the car requires a shorter strut to keep the springs in place over bumps and to give decent wheel travel.
I have heard people say that after putting on springs made for other cars their cars goes around corners like a slot car, truth is there is a difference between lack of sway and grip. A softer spring within reason is best for most applications as it will keep the tire on the ground and give more grip on most surfaces. A spring cut down from a car weighing twice as much as a civic might be too stiff causing the tire to loose contact over the smallest bumps and the ride for a street car would be awful. A much stiffer spring will also require a custom valved strut to be effective even if needed in a full race application. Also think about handling in a emergency, you don't want to be worried about handling when you have to avoid a accident.
Personally I have done the latter I had increased the spring rate on my car to control the sway in the corners and it was better under most race conditions but if I hit even a tiny imperfection in the track the handing would get scary, Once I hit a very small bobble on a straight and spun the car right in the middle of the straight ( I was going about 65 mph at the time so it was kind of scary). I sent the struts in and the shock guy said that running that stiff of spring with the stock valved koni's was not recommended.
So what would I recommend for a Civic that sees mostly street use? I would get a set of openable 73-74 1200 casings and use the Koni inserts. (note the 75s are easier to shorten but the koni inserts for those use grease for corrosion protection and that hardens gluing parts together and those parts some times cant be cleaned and have to be replaced. I'm thinking that the 73-74 koni inserts would be in better shape after sitting on a shelf for 20 years as the are oil filled and may not use the grease at all inside.)
For springs I would try to locate the Dobinson sport springs and combine that with a rear sway bar. If you cant find the casings to use the konis a quality heavy duty or gas charged strut would probably be ok. Handling could be adjusted by playing with front sway bar size and shock adjustment. I would start with a stock front sway bar, if you wanted more under steer go with a bigger sway bar if you want more over steer take the sway bar off. Bushings are also important, and at the very least they should be replaced with new rubber ones.
For competition use it gets allot more complex and $$$$$$$$$$$
Related links
Advance Design
Classic Garage
Sell is Engineering
Whiteline
Fulcrum Suspension
Don
