Front-wheel-drive cars like Honda
Civics' are known for their traction advantage over front-engine, rear-wheel-drive cars. This ability to claw through snow and mud comes from concentrating the weight of the engine, and transmission and final-drive axle (trans-axle) on the drive wheels at the front of the car. The greater the weight on these wheels, the greater the traction on slippery surfaces. Unfortunately this advantage is reduced on high-grip surfaces like a smooth, dry asphalt road or racetrack. When accelerating hard on high-grip pavement, a great deal of the car's weight transfers from the front to the rear.
The simplest way to increase the car's grip on the road either under acceleration or while cornering is to mount better tires.
High-performance tires can improve handling more than any other single change and, for that matter, more than several changes in some cases. The reason is simple: The tires connect the car to the ground. The stronger the connection, the better handling. So great strides can be made by adding high-performance tires, and even greater improvements can be achieved by using competition versions of these tires with soft rubber compounds.
Glenn
185/60R13 seems to be the common tire used based on members of Civic1200.com
comments.
If you put 185/60-13s on your selling yourself (and the car) short. The
original tires for the Civic were 6.00-12 Cross Plies. These have a rolling
diameter of around 590mm. The factory spec for the Civic RS was 155SR13 steel
belted radials which have a rolling diameter around 585mm
If you fit 185/60-13 (rolling diameter around 550mm) then you're gearing the car
down by around 6% (equivalent to fitting a 5.1 final drive instead of the
standard 4 speed's 4.9) - OK for short circuits or autocross (Motokhanas for
those in OZ and the UK!) but not great for fast circuits or highway motoring.
This could however be a valid way of compensating for a too tall final drive.
Depending on rim width, for a road car with 13inch wheels I'd recommend:
155SR13 (original factory spec for the RS on 4.5 inch rims - but looks far too
skinny)
165/75-13
175/70-13
185/65-13
I wouldn't go wider than a 165 on the original 4.5 inch Accord rims. A 5.0 or
5.5 rim actually improves the performance you'll get from a 165 tire because it
lends more stability to the sidewall (by effectively triangulating the
sidewalls). 175s are ok on 5.0 - 6.0inch rims. I would only put a 185 tire on a
5.5 - 6.0 inch rim. They're OK on a 5 inch rim at a pinch, but there's generally
a little to much sidewall bulge for my liking (with resultant loss of feel for
what the tires are doing - because they're actually moving around laterally
within the tire!), but never on a 4.5 inch rim.
Of course if you go to 14x6 inch wheels then 185/60-14 is spot on!
Mike S.
